This is for a zwave temperature/humidity sensor. I’m putting it in a different location and i’d like to reset all the historical data. I tried going to to developer->statistics, but i don’t see a “ramp” icon for this device’s data.
Maybe remove the device, then go to setting/sevices
Run purge (all, meaning don’t keep days) , for that particular device(entities)
And don’t forget to check the brand-page, im sure they have maybe FAQ, howto reset a particular device
By “moving” i actually didn’t mean physically , I think HA wouldn’t figure out, whether you moved it from the kitchen to the bedroom, unless you “told it”
Maybe I have a key lack of knowledge here. Is the historical data stored on the device itself or in HA? My assumption is it’s in HA’s database, and thus the data should be deletable through HA without removing/adding the device?
The last resort would be excluding and re-including the device, which is a pain. But then it’s not clear that would solve anything if the stats are preserved based on the entity ID.
