I’ve got a switch running on home assistant.
I mostly only switch it on via an Alexa routine, so not even using HA.
I switch it off manually with the button on the switch.
It occasionally (several times a day) switches itself off with the message “SW1 turned off triggered by service Switch: Turn off”
Is there a way to find out what is calling this? I can see entries in the logbook and history, but nothing that says what called it.
