jseppeli
(Jarkko)
March 30, 2023, 9:51am
1
Hello
I’m trying to have a template sensor created that would check if “sensor.solis_dc_power_pv1”
has a value greater than 0 then do a calculation else it would set the sensor to 0
Current code looks like this and it is not working
sensors:
energiayhteiso_test_calc:
friendly_name: "Test"
unit_of_measurement: "W"
device_class: power
value_template: >-
{% set excess_power = states('sensor.solis_dc_power_pv1') | float %}
{% if (('excess_power') >0) %}
{{ state('excess_power') * 0.0132 }}
{% else %}
{{ state('energiayhteiso_test_calc') = 0 }}
{% endif %}
Troon
(Troon)
March 30, 2023, 10:08am
2
I’m not surprised. You’re thinking it’s more complicated than it is.
sensors:
device_class: power
value_template: >-
{% set excess_power = states('sensor.solis_dc_power_pv1') | float(0) %}
{% if excess_power > 0 %}
{{ excess_power * 0.0132 }}
{% else %}
0
{% endif %}
You can try this in the Developer Tools / Template editor to check and debug it.
Better to use the modern template sensor format , though, and here with a shorter template that does the same thing:
template:
- sensor:
- name: energiayhteiso_test_calc
device_class: power
value_template: "{{ max(states('sensor.solis_dc_power_pv1')|float(0)*0.0132, 0) }}"
jseppeli
(Jarkko)
March 30, 2023, 10:12am
3
Thank you very much!
Got it working
jseppeli
(Jarkko)
March 30, 2023, 10:16am
4
@Troon Thank you!
The shorter one also works and is a lot nicer what come sto the code
