The standard HA integration with Smartthings has a Stop button entity, but that only turns off the upper or whole oven (if the oven divider is removed). I have a notification that goes to my phone if I leave the oven on, and a “turn off oven” option on the notification. This triggers an action automation, for both that stop button entity, and a rest_command in my configuration.yaml.
You’ll need to generate an API key from Smartthings, or use your existing one; you can do that here
Once you have the API key, you’ll need your device ID for the oven. I got that by running this command in command prompt:
curl -H "Authorization: Bearer YOUR_API_TOKEN" https://api.smartthings.com/v1/devices
With your API key and Device ID, you can create the rest_command in configuration.yaml:
rest_command:
stop_cavity_01:
url: "https://api.smartthings.com/v1/devices/YOUR DEVICE ID/commands"
method: POST
headers:
Authorization: "Bearer YOUR_API_TOKEN"
Content-Type: "application/json"
payload: >
"commands": [
"component": "cavity-01",
"capability": "ovenOperatingState",
"command": "stop"
This rest_command turns off only the lower oven. Enjoy!
