I am running HA OS on a spare laptop using Qemu, all works fine. I am also using PostgreSQL with Timescale (via addon) as my database for recorder.
However, when I have to restart the laptop running this, the HA comes up, but as the addon with the DB takes a minute longer to start, HA recorder cannot connect and fails, leaving HA running, but none of history working, showing up tons of errors. I have to manually restart HA instance itself after a minute (e.g. in http://hainstance:8123/config/system via the button in the top left), and then everything works as expected.
I found out there are more people having this problem, scattered here and there.
Is there a way how I can either:
- let the recorder wait longer
- add some timeout and retry policy
- make HA restart when the DB becomes available
