I’m currently running HA as a VM in Proxmox using an official image.
I’m migrating my NAS to Unraid and need to know if I should use the Community Apps to install Home Assistant, or if I should again create a VM in the Unraid environment.
Just reading here, I would likely create a VM. You so not say if you have any USB sticks,etc. that may need connection to HA. That could complicate the decision.
My set up is a VM with a Conbee II passed through. Straightforward to do. I used a VM rather than a docker for more flexibility and control over resources used.
