First off, I’m new to home assistant so I have probably made a stupid mistake, but any help would be gratefully received.
I want to define the value of a new sensor (“solar_auto_batt_charge_level”) based on another sensor (“solar_auto_batt_charge_temp”) using the following rules:
if “solar_auto_batt_charge_temp” is greater than 2000, then “solar_auto_batt_charge_level” = 2000
If 2000 > “solar_auto_batt_charge_temp” > -3000, the “solar_auto_batt_charge_level” = “solar_auto_batt_charge_temp”
If “solar_auto_batt_charge_temp” is less than than -3000, then “solar_auto_batt_charge_level” = -3000
I have added the following code into my sensor.yaml file which passes the config check, but “solar_auto_batt_charge_level” is reported as “unavailable” in home assistant. Note, “solar_auto_batt_charge_temp” is working correctly and reporting the appropriate values.
solar_auto_batt_charge_level:
friendly_name: Solar Auto Lux Batt charge Level
unit_of_measurement: "W"
device_class: power
value_template: >
{% set car_charge_temp = state('sensor.solar_auto_batt_charge_temp') | float(0) %}
{% if car_charge_temp > 2000.0 %}
2000.0
{% elif 2000.0 > car_charge_temp > -3000.0 %}
{{ (car_charge_temp) | float(0) }}
{% elif car_charge_temp < -3000.0 %}
-3000.0
{% else %}
0.0
{% endif %}
Can anyone tell me what I have done wrong? Thanks in advance.
