I’m working on the automation below:
alias: Frigate work timed notifications
description: ''
- platform: mqtt
topic: frigate/events
payload: new
value_template: '{{ value_json.type }}'
condition: []
- if:
- condition: state
entity_id: input_boolean.disable_person_notifications
state: 'on'
then:
- stop: work-hours-person
error: false
else:
- service: notify.mobile_app_ash_iphone
message: >-
A {{trigger.payload_json["after"]["label"]}} was tested on
{{trigger.payload_json["after"]["camera"]}} camera.
image: >-
https://xxxxxxxxxxxxxxxx.ui.nabu.casa/{{trigger.payload_json["after"]["id"]}}/thumbnail.jpg
tag: '{{trigger.payload_json["after"]["id"]}}'
when: '{{trigger.payload_json["after"]["start_time"]|int}}'
entity_id: camera.{{trigger.payload_json["after"]["camera"]}}
- service: notify.tv
message: >-
- service: notify.mobile_app_ashs_macbook_pro
message: >-
title: Security
mode: single
My expectation is that when input_boolean.disable_person_notifications
is on
, the automation should stop.
However, it always executes the actions after the else, regardless of the state of input_boolean.disable_person_notifications
Is my expectation or config in error?
tom_l
July 9, 2022, 2:37pm
2
You could do that a lot simpler by using that as a condition for the automation.
description: ''
- platform: mqtt
payload: new
condition:
- condition: state
state: 'on'
message: >-
image: >-
message: >-
message: >-
title: Security
mode: single
Thanks for the reply, @tom_l .
I have other stuff to add but can’t get the ‘stop’ to work and am trying to narrow down the problem.
On the face of it, does it seem correct?
I’m trying to do:
IF (x AND y)
OR z
THEN stop
ELSE execute the actions.
123
(Taras)
July 9, 2022, 3:25pm
4
I believe tom_I’s suggestion is the better option.
The go/no-go decision to execute the action
is made by the condition
. If the decision is no-go then the action
is not executed and the automation’s last_triggered
value remains unchanged.
Your version makes the decision within the action
so even if the automation effectively has nothing to do except stop, it must execute the action
to achieve that (and so its last_triggered
value is updated).
I guess if you want last_triggered
to be updated (and a trace generated) even if the automation performs no actual work then your version is the one to use.
gonzotek
(Gonzotek)
July 9, 2022, 7:09pm
5
I ran a simplified version of the if-then action in your original post, which already seemed fine to me, and got the expected results(reached the “then” when the state was ‘on’, which then stopped the automation. Reached the “else” when the state was ‘off’). Try adding logbook.log actions to record the state(s) of things. Also check the traces to see if you can spot anything amiss.
if:
- condition: state
entity_id: light.attic
state: 'on'
then:
- service: logbook.log
message: "Stopping. Light state: {{ states('light.attic') }}"
error: false
else:
message: "Continuing. Light state: {{ states('light.attic') }}"
