hi I am strugling with the IF then Else in Yaml. I tried via the settings/automation but it won’t help.
I have a thermostat with 2 variables:
the temperature via the sensor and the the temperature that I want to have is via the thermostat
if the temperature via the sensor is lower than what I want, then all me aircos should start blowing heat.
But I can’t start with the if then else part, saying compairing the 2 variables.
Can you help me?
thank you very much
Numeric State triggers can accept the entity id of number helpers (input_number entities), number and sensor entities that contain a numeric value in the above and below thresholds.
This is a basic sketch since you have provided very little information about your entities and setup. Depending on how you have your entities configured and the specifics of what you want to do, you may also be interested in these other options:
