How would I go about a TV time scene that after a trigger and a condition of under 400 lumens outside, turns on scene (i.e. All media components) with lights, otherwise turns on scene without the lights?
I understand the trigger and most of the condition code, but I don’t know how to implement the two final outcomes.
Is this more a job for App daemon? If so is there an example I could make use of?
The effect is that if I triggered any activity on the Harmony Hub, it would bring the lights up to full, wait a minute and a half and then slowly fade down. But only if it’s getting dark.
I don’t believe there’s a possibility of an “else”. There a couple of ways I’ve handled stuff like this, none are elegant:
For items that are successive or can stack (can’t think of a way to word this), I’ll have a sequence and take advantage of the fact that I can quit from it by using conditions. For instance, I might want a lamp to come on dim in some situations, bright in others. I start with the dim command, then a condition test, then the bright command.
I’ll sometimes call two scripts and plan so that one will fail based on conditions. That’s not so much an “if/else” as an “or”.
I think that this is probably a situation for Appdaemon, but I haven’t tackled using it yet.
It was this kind of more complex requirement, specifically an else as well as more nested logic that made me write AppDaemon, this would be a good usecase for a simple App.
Bit of a thread hijack, but where can I find a “getting started” so that I know how to install AppDaemon? I know there’s a Q&A page and a blog post - but I’m not seeing any “getting started” kind of info. Thx!
Is there a code repository for Apps that people can share? The joy of github is being able to learn by searching millions of examples of code. If not, what would be a good way of providing a catalog of shared code? (Something similar to Share your projects category but for Apps)?
