noxx
(Ralf B)
1
Hello, can i add here a if-then query?
- alias: Pool_Chlor_5s_On
- entity_id: switch.buero_ralf_stehlampe02
platform: state
to: 'on'
- condition: numeric_state
entity_id: sensor.wf_192_168_1_156_orp
above: 700
below: 720
- data:
entity_id: switch.pool_dosierung_chlor
service: switch.turn_on
- entity_id: timer.timer_5s
service: timer.start
- alias: Pool_Chlor_5s_Off
- event_data:
event_type: timer.finished
platform: event
- alias: ''
service: switch.turn_off
switch starts for 5s if the value is between 700 and 720
i want
if value 0 - 500
then timer = 30s
500 - 600
timer = 20s
600 - 700
timer = 10s
700 - 720
timer = 5s
720
timer = 0 / off
Also, you are missing the condition
header in the first automation.
tmjpugh
(Tmjpugh)
3
Trigger will be the state change of the value.
You may set if-then action based off the value. This is option in automation UI
aceindy
(Aceindy)
4
I would use something like:
platform: state
to: "on"
actionp:
- choose:
- conditions: numeric_state
above: 700
below: 720
sequence:
- service: switch.turn_on
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
- service: switch.turn_off
above: 600
below: 700
sequence:
- delay:
hours: 0
minutes: 0
seconds: 10
milliseconds: 0
above: 500
below: 600
sequence:
- delay:
hours: 0
minutes: 0
seconds: 20
milliseconds: 0
etcetc
I probably haven’t got all parameters right, but hope you understood the general concept ![:wink: :wink:](https://community.home-assistant.io/images/emoji/twitter/wink.png?v=10)
guess you could shorten it a little bit by introducing a variable, but there is no real need for that ![:smiley: :smiley:](https://community.home-assistant.io/images/emoji/twitter/smiley.png?v=10)
