can you create an if-then rule and what should it look like?
If sensor A above value X
then turn on relay 1 when sensor B is above value Y.
If sensors A and B fall below the set value, relay 1 switches off.
I can’t get this problem under control.
Currently I’m doing it like this:
- platform: home assistant
name: "Power Generation A"
entity_id: sensor.input_power
on_value_range:
- above: 1520
then:
- switch.turn_on: hk_1
- below: 1500
then:
- switch.turn_off: hk_1
entity_id: sensor.battery_state_of_capacity
on_value_range:
- below: 95
then:
But it just doesn’t work like that…
The problem is me with my limited skills
gerald
