[{"id":"e286e3660606b50e","type":"api-current-state","z":"14c365016f5c23b5","name":"Z17 Violated","server":"325b32af.71ce1e","version":3,"outputs":2,"halt_if":"Normal","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.elkm1_jm_bedroom_1a","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"zone","propertyType":"msg","value":"","valueType":"entityState"},{"property":"zone","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":270,"y":260,"wires":[["a8136d30535e0dd4","df1f5da04ed1be57","2cbdc1e94ec9b26b"],[]]},{"id":"5a3ec7d01bd279a0","type":"e-mail","z":"14c365016f5c23b5","server":"smtp.office365.com","port":"587","secure":false,"tls":true,"name":"[email protected]","dname":"Send email","x":1210,"y":380,"wires":[]},{"id":"df1f5da04ed1be57","type":"api-current-state","z":"14c365016f5c23b5","name":"Right Therm is not idle","server":"325b32af.71ce1e","version":3,"outputs":2,"halt_if":"idle","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.rightside_hvacaction","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"rtherm","propertyType":"msg","value":"","valueType":"entityState"},{"property":"rtherm","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":260,"wires":[["bcb2c50706865797"],[]]},{"id":"2cbdc1e94ec9b26b","type":"api-current-state","z":"14c365016f5c23b5","name":"Left Therm is not idle","server":"325b32af.71ce1e","version":3,"outputs":2,"halt_if":"idle","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.leftside_hvacaction","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"ltherm","propertyType":"msg","value":"","valueType":"entityState"},{"property":"ltherm","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":500,"y":320,"wires":[["bcb2c50706865797"],[]]},{"id":"300c630574829432","type":"function","z":"14c365016f5c23b5","name":"Email info","func":"msg.topic = \"Haledon Window Open\"\nmsg.payload = \"A window is open while heating or cooling. \"\n + \"<br>\"\n + \"<br> Haledon\"\n + \"<br>\"\n + \"<br> Window Information\"\n + \"<br>\"\n + \"<br> - Zone: \" + msg.zone.attributes.index\n + \"<br> - Name: \" + msg.zone.attributes.friendly_name\n + \"<br> - Status: \" + msg.zone.attributes.logical_status\n + \"<br>\"\n + \"<br> Thermostat Information\"\n + \"<br>\"\n + \"<br> Right Side Thermostat\"\n + \"<br> - Current Temperature: \" + msg.rtherm.attributes.current_temperature\n + \"<br> - Setpoint: \" + msg.rtherm.attributes.temperature\n + \"<br> - Fan Mode: \" + msg.rtherm.attributes.fan_mode\n + \"<br> - Humidity: \" + msg.rtherm.attributes.current_humidity\n + \"<br> - HVAC Mode: \" + msg.rtherm.state\n + \"<br>\"\n + \"<br> Left Side Thermostat\"\n + \"<br> - Current Temperature: \" + msg.ltherm.attributes.current_temperature\n + \"<br> - Setpoint: \" + msg.ltherm.attributes.temperature\n + \"<br> - Fan Mode: \" + msg.ltherm.attributes.fan_mode\n + \"<br> - Humidity: \" + msg.ltherm.attributes.current_humidity\n + \"<br> - HVAC Mode: \" + msg.ltherm.state\n + \"<br>\"\n + \"<br> Basement Thermostat\"\n + \"<br> - Current Temperature: \" + msg.bastherm.attributes.current_temperature\n + \"<br> - Setpoint: \" + msg.bastherm.attributes.temperature\n + \"<br> - Fan Mode: \" + msg.bastherm.attributes.fan_mode\n + \"<br> - Humidity: \" + msg.bastherm.attributes.current_humidity\n + \"<br> - HVAC Mode: \" + msg.bastherm.state\n return msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1120,"y":240,"wires":[["5a3ec7d01bd279a0"]]},{"id":"a8136d30535e0dd4","type":"api-current-state","z":"14c365016f5c23b5","name":"basement therm is not idle","server":"325b32af.71ce1e","version":3,"outputs":2,"halt_if":"idle","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.basement_hvacaction","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"bastherm","propertyType":"msg","value":"","valueType":"entityState"},{"property":"bastherm","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":520,"y":200,"wires":[["bcb2c50706865797"],[]]},{"id":"cb0c30b63a65faf3","type":"inject","z":"14c365016f5c23b5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"10","topic":"","payload":"","payloadType":"date","x":80,"y":260,"wires":[["e286e3660606b50e"]]},{"id":"bcb2c50706865797","type":"api-current-state","z":"14c365016f5c23b5","name":"basement therm full status","server":"325b32af.71ce1e","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_32_f2_72_group_1","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"bastherm","propertyType":"msg","value":"","valueType":"entityState"},{"property":"bastherm","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":780,"y":260,"wires":[["5e78f28b90e5e3d8"]]},{"id":"5e78f28b90e5e3d8","type":"api-current-state","z":"14c365016f5c23b5","name":"Right Therm full status","server":"325b32af.71ce1e","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_right_side","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"rtherm","propertyType":"msg","value":"","valueType":"entityState"},{"property":"rtherm","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":800,"y":340,"wires":[["0c8d3a462d1991ca"]]},{"id":"0c8d3a462d1991ca","type":"api-current-state","z":"14c365016f5c23b5","name":"Left Therm full status","server":"325b32af.71ce1e","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"climate.thermostat_left_side","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"ltherm","propertyType":"msg","value":"","valueType":"entityState"},{"property":"ltherm","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":1040,"y":300,"wires":[["300c630574829432"]]},{"id":"325b32af.71ce1e","type":"server","name":"Home Assistant","addon":true}]
