Iframe_panel sorting feature
I just want to ask for an additional configuration variable for the iframe_panel for sort the entrys manual.
not (currently) in alphabetic order…
Can this be possible?
BTW: i use a docker environment for my HA instance… So it would be cool to setup the iframe_panel url to the docker container hostname, too… (if all the used container are in the same docker network)
Kind regards…
Don’t forget to vote for your own idea!
already done…
You can sort them however you like.
OK…
So please lit up this bulb and tell how…
I was looking for the docs on this, but can’t find any!
Long click on the sidebar toggle. Where the mouse is in the following screenshot. You can then drag and drop to your hearts content.
insane…
Thank you… It worked…
