However, when I use the iframe card in Lovelace, it renders blank. No errors in the logs. Default HTTPS home assistant webpage in the card renders fine.
Thanks - I don’t think that’s it because it’s designed to be embedded. They even give iframe embed tags with specified widths and heights. Maybe given you can’t specify width and height in the iframe card that’s the issue?
