IFTTT Call a HA script
The last couple of days I have been struggling to get IFTTT working to call a HA script.
I want to call a script once our Rachio Smart Garden Sprinkler stop a zone.
I wanted to share how I got it working:
First create a script in HA for example rachio_off.yaml:
alias: 'rachio_off'
sequence:
- service: input_boolean.turn_off
    entity_id: input_boolean.rachio_switch_zone1
    entity_id: input_boolean.rachio_switch_zone2
    entity_id: input_boolean.rachio_switch_zone3
    entity_id: input_boolean.rachio_switch_zone4
    entity_id: input_boolean.rachio_switch_zone5
Next create a new applet in IFTTT with a web-request:
URL: https://www.mydomain.com:8123/api/services/script/rachio_off?api_password=MyPassword
Method: Post
Content Type: application/sjon
Body: {“entity_id”: [“script.rachio_off”]}
The main trick I got it working was placing the square brackets. All the samples I found in this blog or others where without.
A good place to debug your calls is: hurl.it
Interestingly, I have dozens of ifttt recipes to run scripts in HA, and I don’t use the square brackets for any of them.
{"entity_id": "script.movie_mode_on"}
Thank you. I tried that also. But did not work ?
