IFTTT integration issues
I am trying to follow this integration:
I have the IFTTT side setup
Tested the webhook and it works when sending it from HA to IFTTT
I am now trying to work on the return from IFTTT to HA
According to doc, it says to create an automation like so
But when I try to enter that into a new automation through YAML, I get this malformed error
Hi, probably you already fixed your problem,
but here is my working code example:
- alias: Test
  - platform: event
    event_type: ifttt_webhook_received
    event_data:
      action: call_service
  - data:
      entity_id: '{{ trigger.event.data.entity_id }}'
    service: '{{ trigger.event.data.service }}'
If this is not working, I would expect that something in IFTTT is configurated wrong. You should post the configuration of the “that” reaction…
First of all, I would expect sth. is wrong with the URL
