hi all. i’ve been trying to get my ifttt webhooks to work and seem to be running into some kind of problem, which i’m thinking is the integration. I have added the integration to home assistant, and see it listed in my integration. I’ve successfully set up the ifttt side, and from the developer tools/events i can listen and see the ifttt_webhook_received come through with data. I have added the default automation (via automation.yaml as it seems I can’t get it via the UI) and did the config test… but nothing happens with the automation. If i go back to ‘test’ via the documentation, it says I can go to developer tools/services and select IFTTT:Trigger. IFTTT:Triggeer DOES NOT show up. Could there be something wrong with integration…or… any other ideas? THANKS in advance! (running Home assistant core 2022.6.7 via Synology via Docker) please let me know of any other info that might be important
