Hi community
I recently bought a Withings Sleep Analyzer which should detect if I am in the bed or not. I did a lot of research and noticed that the Withings integration is not working very well/reliable and IFTTT should be considered. I tried to set up things like here:Withings sleep help - #4 by wills106
what I have done so far:
- configured the Sleep analyzer via the Health mate app
- installed IFTTT-integration in HA
- created an applet
- created an input.boolean which should be triggered via IFTTT
the issue
unfortunately the input-boolean does not get turned on if the mat recognizes that I am in bed. I can confirm that the sensor is working as the log in IFTTT ran a couple of times (testwise).
this is how the applet looks like:
In the URL-section I copied the nabu-casa URL (I use the cloud) which has been generated when I installed the IFTTT-integration. I also copied the key from IFTTT (Get Started - IFTTT) and pasted it in my config.yaml.
ifttt:
key: XXX
I would be glad to get some help and may help others which encounter the same issue. I spent hours of research but could not find a solution/reason why it doesnt work as supposed.
Kind regards
Andrew
