Edit: turns out i had modified my backup groups.yaml file, not my active file. Doh!
I must be doing something wrong here but try as i might i can’t figure it out. I did some searching and looking at others HA setups and watched a Bruh vid on the subject but i’m just not getting it and any changes i make to groups.yaml now are not represented on the UI when reloaded.
I’ve got 4 Google devices: 2 chromecast, 1 chromecast audio and 1 google home mini. All of them are showing in my device list and if i cast something it updates correctly and i can control it.
My current groups.yaml is below
### VIEWS = TABS ###
default_view:
view: yes
entities:
- updater.updater
- group.main_nest
- group.main_nest2
- group.daily_forecast
- group.main_presence
- sun.sun
main_environmental_view:
view: yes
entities:
- group.main_nest
- group.main_nest2
main_front_room_view:
view: yes
entities:
- group.main_front_room
- media_player.front_room_amp
- media_player.front_room_tv
main_kitchen_view:
view: yes
entities:
- group.main_kitchen
main_master_bedroom_view:
view: yes
entities:
- group.main_master_bedroom
- media_player.master_bedroom_mini
- media_player.master_bedroom_tv
main_garage_view:
name: Garage / Garden
view: yes
entities:
- group.main_garage
- group.main_garden
### GROUPS = TILES ###
main.presence:
entities:
- device_tracker.joe_6p
- device_tracker.rosie_6p
main_nest:
entities:
- climate.front_room
- binary_sensor.front_room_thermostat_online
- binary_sensor.hallway_nest_protect_online
- sensor.front_room_thermostat_operation_mode
- sensor.front_room_thermostat_target
- sensor.front_room_thermostat_temperature
- binary_sensor.front_room_thermostat_fan
- binary_sensor.front_room_thermostat_has_leaf
- binary_sensor.front_room_thermostat_is_locked
- binary_sensor.front_room_thermostat_is_using_emergency_heat
- sensor.front_room_thermostat_humidity
- sensor.front_room_thermostat_hvac_state
main_nest2:
name: CO Detectors
entities:
- sensor.hallway_nest_protect_battery_health
- sensor.hallway_nest_protect_co_status
- sensor.hallway_nest_protect_smoke_status
daily_forecast:
entities:
- sensor.pws_weather_1d_metric
- sensor.pws_weather_1n_metric
- sensor.pws_weather_2d_metric
- sensor.pws_weather_2n_metric
- sensor.pws_weather_3d_metric
- sensor.pws_weather_4n_metric
- sensor.pws_weather_5d_metric
- sensor.pws_weather_5n_metric
main_front_room:
entities:
- switch.Front_Room_TV
- switch.Electric_Heater_FR
- switch.front_room_lamp
- switch.Christmas_Tree
main_kitchen:
entities:
- switch.Kitchen_Lights
main_master_bedroom:
entities:
- light.master_bedroom_light
main_garage:
entities:
- cover.garage_door_1
- binary_sensor.garage_door_1
main_garden:
entities:
- switch.Garden_Lights
Can someone give me a bit of a steer on what i’m doing wrong. If you need more information around my config please let me know. I will probably change this layout a little, but i’m stumped by why when i make changes (and i’ve made many changes) this isn’t updating in the UI but also why the google devices aren’t showing up in the UI.
