I reported to Rainforest support that the Local API HA uses fails to connect once a day at the same time of day.
This was their response:
“The reason for your device getting an error every day around 10:08 is due to crontabs. This means that your device does a quick reboot once a day at that time. It’s a feature that’s a part of the Linux operating system.
Hard to say whether you should wait longer than 10 seconds or ignore a single connect error. I would suggest trying both, and seeing what works. My main concern for ignoring a single connect error is that if you don’t have a stable meter connection you might run into issues with that logic.
I assume that “your device” means my Eagle-200 (firmware 3.17.1.480)
Is there a way ignore this daily error?
