Ignore reolink warnings
My reolink cams are set to auto update. I always get reolink warnings in HA.
I ignore it but several days later I get another one. When I go to manually update it says I’m already at the latest firmware.
Is there a way to make this less intrusive? A 0.0.0.x is a nightly build update hardly worth a warning.
I have not done this but you may be able to change the log level for that device to not set.
That looks right, but I couldn’t find the component name to use. home-assistant.log didn’t have any entries so I just guessed
logger:
logs:
homeassistant.components.reolink: warning
I’ve had it set with code
logger:
  logs:
    homeassistant.components.reolink: error
However I’m still getting
I’m not sure how to get the right device path
