IHC Climate temperature control
Hi.
My heat is controlled with my IHC, which is a Schneider product that controlles most of my light, and heat in the house. IHC has a integration that defines most entities in the house automaticaly.
The temperature of every room is defined as a sensor for every room, and the i can write the setpoint in IHC with a service. The state of the heatvalve is also availeble as a switch.
Butt, it is not defined as a “Climate” entity, and that means that i cant figure out hov to control and monitor each roomtemperature in lovelace, vith a thermostat card, or similar. I made a picture-element which shows the temperatures, but i would like to make it possible to change the setpoint from the same card.
Any idea how to solve that?
