IHC Integration - Fails
IHC Integration fails
My IHC integration fails to load.
I get all sorts of errors in my log and in my entitys.
My Installation has been working fine up ontil a couble of month ago, but now nothing works.
Can anyone figure out what might be wrong?
I get this from my log:
Logger: homeassistant.setup
Source: setup.py:404
First occurred: 1:03:08 PM (5 occurrences)
Last logged: 1:03:08 PM
Unable to prepare setup for platform ‘ihc.binary_sensor’: Unable to set up component.
Unable to prepare setup for platform ‘ihc.light’: Unable to set up component.
Unable to prepare setup for platform ‘ihc.switch’: Unable to set up component.
All my IHC entitys has this fault:
My Configfile is setup like this:
ihc:
There’s most likely an error before that which contains the real reason the integration is failing to set up. Make sure your IP address has not changed for the device.
My IP is the same. No change there.
Do you have an idea of where the problem could be?
In my log, i can see some errors, but it dosent look lige any of them has anything to do with the IHC Integration.
Please download the actual logs and past them here, not a picture of the UI. There’s a button at the bottm.
How do I attach the log-file?
You can use dpaste.org and copy the contents there or paste the contents into the reply
I’m trying dpaste.org:
https://dpaste.org/LRm9x
