Hey,
I create an awesome script. My problem with the IKEA Remote was that you can not change the light bulbs. Every light bulb needs its own remote (if you want every function from the remote [brightness, temperature]). If you do a double click (virtual double click) with the center button, then you choose a new light bulb. The light bulb will blink (toggle, 500ms wait, toggle).
The blueprint is based on the awesome blueprint (IKEA 5 Buttons).
I used some helper. An integer input for the index of the current light bulb and some stuff from awesome blueprints.
I need help to create a “real” blue print. A lot of automation is in the input (configured with the ui). I want create a more generic blueprint. The only thing that you need to configure is the input (3, 4 or 5 Light bulbs…).
The basic idea is, after a double click to increase the counter (or set to 0) and then if you do a normal center click a choose will select the entity with that index.
The blueprint:
blueprint:
description: '# '
domain: automation
input:
integration:
name: (Required) Integration
selector:
select:
options:
- deCONZ
- ZHA
- Zigbee2MQTT
controller_device:
name: (deCONZ, ZHA) Controller Device
description: The controller device to use for the automation. Choose a value
only if the remote is integrated with deCONZ, ZHA.
default: ''
selector:
device: {}
controller_entity:
name: (Zigbee2MQTT) Controller Entity
default: ''
selector:
entity:
domain: sensor
first_light_blub:
name: First Light Blub
description: The light entity to control.
selector:
entity:
domain: light
second_light_blub:
name: Second Light Blub
selector:
entity:
domain: light
third_light_blub:
selector:
entity:
domain: light
speed:
selector:
number:
min: 100
max: 1000
step: 100
unit_of_measurement: milliseconds
mode: slider
default: 500
speed_brightness:
name: Speed Brightness
selector:
number:
min: 100
max: 1000
step: 100
mode: slider
default: 500
helper_last_controller_event:
name: (Required) Helper - Last Controller Event
default: ''
selector:
entity:
domain: input_text
helper_light_index:
default: ''
selector:
entity:
domain: input_number
action_button_left_short:
name: (Optional) Left button short press
description: Action to run on short left button press.
default: []
selector:
action: {}
action_button_left_long:
name: (Optional) Left button long press
description: Action to run on long left button press.
default: []
selector:
action: {}
action_button_left_release:
name: (Optional) Left button release
description: Action to run on left button release after long press.
default: []
selector:
action: {}
action_button_left_double:
name: (Optional) Left button double press
description: Action to run on double left button press.
default: []
selector:
action: {}
action_button_right_short:
name: (Optional) Right button short press
description: Action to run on short right button press.
default: []
selector:
action: {}
action_button_right_long:
name: (Optional) Right button long press
description: Action to run on long right button press.
default: []
selector:
action: {}
action_button_right_release:
name: (Optional) Right button release
description: Action to run on right button release after long press.
default: []
selector:
action: {}
action_button_right_double:
name: (Optional) Right button double press
description: Action to run on double right button press.
default: []
selector:
action: {}
action_button_up_short:
name: (Optional) Up button short press
description: Action to run on short up button press.
default: []
selector:
action: {}
action_button_up_long:
name: (Optional) Up button long press
description: Action to run on long up button press.
default: []
selector:
action: {}
action_button_up_release:
name: (Optional) Up button release
description: Action to run on up button release after long press.
default: []
selector:
action: {}
action_button_up_double:
name: (Optional) Up button double press
description: Action to run on double up button press.
default: []
selector:
action: {}
action_button_down_short:
name: (Optional) Down button short press
description: Action to run on short down button press.
default: []
selector:
action: {}
action_button_down_long:
name: (Optional) Down button long press
description: Action to run on long down button press.
default: []
selector:
action: {}
action_button_down_release:
name: (Optional) Down button release
description: Action to run on down button release after long press.
default: []
selector:
action: {}
action_button_down_double:
name: (Optional) Down button double press
description: Action to run on double down button press.
default: []
selector:
action: {}
action_button_center_short:
name: (Optional) Center button short press
description: Action to run on short center button press.
default: []
selector:
action: {}
action_button_center_long:
name: (Optional) Center button long press
description: Action to run on long center button press.
default: []
selector:
action: {}
action_button_center_double:
name: (Optional) Center button double press
description: Action to run on double center button press.
default: []
selector:
action: {}
button_left_long_loop:
name: (Optional) Left button long press - loop until release
description: Loop the left button action until the button is released.
default: false
selector:
boolean: {}
button_left_long_max_loop_repeats:
name: (Optional) Left button long press - Maximum loop repeats
description: Maximum number of repeats for the custom action, when looping is
enabled. Use it as a safety limit to prevent an endless loop in case the corresponding
stop event is not received.
default: 500
selector:
number:
min: 1.0
max: 5000.0
mode: slider
step: 1.0
button_right_long_loop:
name: (Optional) Right button long press - loop until release
description: Loop the right button action until the button is released.
default: false
selector:
boolean: {}
button_right_long_max_loop_repeats:
name: (Optional) Right button long press - Maximum loop repeats
default: 500
selector:
number:
min: 1.0
max: 5000.0
mode: slider
step: 1.0
button_up_long_loop:
name: (Optional) Up button long press - loop until release
description: Loop the up button action until the button is released.
default: false
selector:
boolean: {}
button_up_long_max_loop_repeats:
name: (Optional) Up button long press - Maximum loop repeats
default: 500
selector:
number:
min: 1.0
max: 5000.0
mode: slider
step: 1.0
button_down_long_loop:
name: (Optional) Down button long press - loop until release
description: Loop the down button action until the button is released.
default: false
selector:
boolean: {}
button_down_long_max_loop_repeats:
name: (Optional) Down button long press - Maximum loop repeats
default: 500
selector:
number:
min: 1.0
max: 5000.0
mode: slider
step: 1.0
button_left_double_press:
name: (Optional) Expose left button double press event
description: Choose whether or not to expose the virtual double press event
for the left button. Turn this on if you are providing an action for the left
button double press event.
default: false
selector:
boolean: {}
button_right_double_press:
name: (Optional) Expose right button double press event
for the right button. Turn this on if you are providing an action for the
right button double press event.
default: false
selector:
boolean: {}
button_up_double_press:
name: (Optional) Expose up button double press event
for the up button. Turn this on if you are providing an action for the up
default: false
selector:
boolean: {}
button_down_double_press:
name: (Optional) Expose down button double press event
for the down button. Turn this on if you are providing an action for the down
default: false
selector:
boolean: {}
button_center_double_press:
name: (Optional) Expose center button double press event
for the center button. Turn this on if you are providing an action for the
center button double press event.
default: false
selector:
boolean: {}
helper_double_press_delay:
name: (Optional) Helper - Double Press delay
description: Max delay between the first and the second button press for the
double press event. Provide a value only if you are using a double press action.
Increase this value if you notice that the double press action is not triggered
properly.
default: 500
selector:
number:
min: 100.0
max: 5000.0
mode: box
step: 10.0
helper_debounce_delay:
name: (Optional) Helper - Debounce delay
description: Delay used for debouncing RAW controller events, by default set
to 0. A value of 0 disables the debouncing feature. Increase this value if
you notice custom actions or linked Hooks running multiple times when interacting
with the device. When the controller needs to be debounced, usually a value
of 100 is enough to remove all duplicate events.
default: 0
selector:
number:
min: 0.0
max: 1000.0
mode: box
step: 10.0
variables:
first_light_blub: !input 'first_light_blub'
second_light_blub: !input 'second_light_blub'
third_light_blub: !input 'third_light_blub'
var_speed: !input 'speed'
var_brightness: !input 'speed_brightness'
integration: !input 'integration'
button_left_long_loop: !input 'button_left_long_loop'
button_left_long_max_loop_repeats: !input 'button_left_long_max_loop_repeats'
button_left_double_press: !input 'button_left_double_press'
button_right_long_loop: !input 'button_right_long_loop'
button_right_long_max_loop_repeats: !input 'button_right_long_max_loop_repeats'
button_right_double_press: !input 'button_right_double_press'
button_up_long_loop: !input 'button_up_long_loop'
button_up_long_max_loop_repeats: !input 'button_up_long_max_loop_repeats'
button_up_double_press: !input 'button_up_double_press'
button_down_long_loop: !input 'button_down_long_loop'
button_down_long_max_loop_repeats: !input 'button_down_long_max_loop_repeats'
button_down_double_press: !input 'button_down_double_press'
button_center_double_press: !input 'button_center_double_press'
helper_light_index: !input 'helper_light_index'
helper_last_controller_event: !input 'helper_last_controller_event'
helper_double_press_delay: !input 'helper_double_press_delay'
helper_debounce_delay: !input 'helper_debounce_delay'
integration_id: '{{ integration | lower }}'
adjusted_double_press_delay: '{{ [helper_double_press_delay - helper_debounce_delay,
100] | max }}'
actions_mapping:
deconz:
button_left_short:
- '4002'
button_left_long:
- '4001'
- '4003'
button_right_short:
- '5002'
button_right_long:
- '5001'
- '5003'
button_up_short:
- '2002'
button_up_long:
- '2001'
button_up_release:
- '2003'
button_down_short:
- '3002'
button_down_long:
- '3001'
- '3003'
- '1002'
button_center_long:
- '1001'
zha:
button_left_short:
- press_257_13_0
button_left_long:
- hold_3329_0
- release
button_right_short:
- press_256_13_0
button_right_long:
- hold_3328_0
- release
button_up_short:
- step_with_on_off_0_43_5
button_up_long:
- move_with_on_off_0_83
- move_with_on_off_0_84
button_up_release:
- stop
button_down_short:
- step_1_43_5
button_down_long:
- move_1_83
- move_1_84
- stop
- toggle
button_center_long:
- press_2_0_0
zigbee2mqtt:
button_left_short:
- arrow_left_click
button_left_long:
- arrow_left_hold
- arrow_left_release
button_right_short:
- arrow_right_click
button_right_long:
- arrow_right_hold
- arrow_right_release
button_up_short:
- brightness_up_click
button_up_long:
- brightness_up_hold
button_up_release:
- brightness_up_release
button_down_short:
- brightness_down_click
button_down_long:
- brightness_down_hold
- brightness_down_release
- toggle
button_center_long:
- toggle_hold
button_left_short: '{{ actions_mapping[integration_id]["button_left_short"] }}'
button_left_long: '{{ actions_mapping[integration_id]["button_left_long"] }}'
button_left_release: '{{ actions_mapping[integration_id]["button_left_release"]
button_right_short: '{{ actions_mapping[integration_id]["button_right_short"] }}'
button_right_long: '{{ actions_mapping[integration_id]["button_right_long"] }}'
button_right_release: '{{ actions_mapping[integration_id]["button_right_release"]
button_up_short: '{{ actions_mapping[integration_id]["button_up_short"] }}'
button_up_long: '{{ actions_mapping[integration_id]["button_up_long"] }}'
button_up_release: '{{ actions_mapping[integration_id]["button_up_release"] }}'
button_down_short: '{{ actions_mapping[integration_id]["button_down_short"] }}'
button_down_long: '{{ actions_mapping[integration_id]["button_down_long"] }}'
button_down_release: '{{ actions_mapping[integration_id]["button_down_release"]
button_center_short: '{{ actions_mapping[integration_id]["button_center_short"]
button_center_long: '{{ actions_mapping[integration_id]["button_center_long"] }}'
integrations_with_prev_event_storage:
- zha
controller_entity: !input 'controller_entity'
controller_device: !input 'controller_device'
controller_id: '{% if integration_id=="zigbee2mqtt" %}{{controller_entity}}{% else
%}{{controller_device}}{% endif %}'
mode: restart
max_exceeded: silent
- platform: event
event_type: state_changed
event_data:
entity_id: !input 'controller_entity'
- platform: event
event_type:
- deconz_event
- zha_event
event_data:
device_id: !input 'controller_device'
condition:
- condition: and
conditions:
- '{%- set trigger_action -%} {%- if integration_id == "zigbee2mqtt" -%} {{ trigger.event.data.new_state.state
}} {%- elif integration_id == "deconz" -%} {{ trigger.event.data.event }} {%-
elif integration_id == "zha" -%} {{ trigger.event.data.command }}{{"_" if trigger.event.data.args|length
> 0}}{{ trigger.event.data.args|join("_") }} {%- endif -%} {%- endset -%} {{ trigger_action
not in ["","None"] }}'
- '{{ integration_id != "zigbee2mqtt" or trigger.event.data.new_state.state != trigger.event.data.old_state.state
- delay:
milliseconds: !input 'helper_debounce_delay'
- variables:
trigger_action: '{%- if integration_id == "zigbee2mqtt" -%} {{ trigger.event.data.new_state.state
> 0}}{{ trigger.event.data.args|join("_") }} {%- endif -%}'
trigger_delta: '{{ (as_timestamp(now()) - as_timestamp((states(helper_last_controller_event)
| from_json).last_triggered if helper_last_controller_event is not none and
(states(helper_last_controller_event) | regex_match("^\{(\".*\": \".*\"(, )?)*\}$"))
else "1970-01-01 00:00:00")) * 1000 }}'
last_controller_event: '{{ (states(helper_last_controller_event) | from_json).trigger_action
if helper_last_controller_event is not none and (states(helper_last_controller_event)
| regex_match("^\{(\".*\": \".*\"(, )?)*\}$")) else "" }}'
- service: input_text.set_value
entity_id: !input 'helper_last_controller_event'
value: '{{ {"trigger_action":trigger_action,"last_triggered":now()|string} | to_json
- choose:
- conditions: '{{ trigger_action | string in button_left_short }}'
sequence:
- choose:
- conditions: '{{ button_left_double_press }}'
sequence:
- choose:
- conditions: '{{ trigger_action | string in states(helper_last_controller_event)
and trigger_delta | int <= helper_double_press_delay | int }}'
sequence:
value: '{{ {"trigger_action":"double_press","last_triggered":now()
| string} | to_json }}'
- event: ahb_controller_event
event_data:
controller: '{{ controller_id }}'
action: button_left_double
- service: input_number.set_value
entity_id: !input 'helper_light_index'
value: >
{% if (states(helper_light_index) | int) >= 2 %}
{{ 0 | int }}
{% else %}
{{ (states(helper_light_index) | int) + 1 | int }}
{% endif %}
- choose:
- conditions: []
sequence: !input 'action_button_left_double'
default:
- delay:
milliseconds: '{{ adjusted_double_press_delay }}'
event_data:
action: button_left_short
- choose:
- conditions: []
sequence: !input 'action_button_left_short'
default:
event_data:
- choose:
- conditions: []
- conditions: '{{ trigger_action | string in button_left_long }}'
sequence:
event_data:
action: button_left_long
- choose:
- conditions: '{{ button_left_long_loop }}'
sequence:
- repeat:
while: '{{ repeat.index < button_left_long_max_loop_repeats | int }}'
sequence: !input 'action_button_left_long'
default: !input 'action_button_left_long'
- conditions:
- '{{ trigger_action | string in button_left_release }}'
- '{{ not integration_id in integrations_with_prev_event_storage or last_controller_event
sequence:
event_data:
action: button_left_release
- choose:
- conditions: []
sequence: !input 'action_button_left_release'
- conditions: '{{ trigger_action | string in button_right_short }}'
sequence:
- choose:
- conditions: '{{ button_right_double_press }}'
sequence:
- choose:
sequence:
value: >
{% if (states(helper_light_index) | int) == 0 %}
{{ 2 | int }}
{% else %}
{{ (states(helper_light_index) | int) - 1 | int }}
{% endif %}
event_data:
action: button_right_double
- choose:
- conditions: []
sequence: !input 'action_button_right_double'
default:
- delay:
event_data:
action: button_right_short
- choose:
- conditions: []
sequence: !input 'action_button_right_short'
default:
event_data:
- choose:
- conditions: []
- conditions: '{{ trigger_action | string in button_right_long }}'
sequence:
event_data:
action: button_right_long
- choose:
- conditions: '{{ button_right_long_loop }}'
sequence:
- repeat:
while: '{{ repeat.index < button_right_long_max_loop_repeats | int }}'
sequence: !input 'action_button_right_long'
default: !input 'action_button_right_long'
- conditions:
- '{{ trigger_action | string in button_right_release }}'
sequence:
event_data:
action: button_right_release
- choose:
- conditions: []
sequence: !input 'action_button_right_release'
- conditions: '{{ trigger_action | string in button_up_short }}'
sequence:
- choose:
- conditions: '{{ button_up_double_press }}'
sequence:
- choose:
sequence:
event_data:
action: button_up_double
- choose:
- conditions: []
sequence: !input 'action_button_up_double'
default:
- delay:
event_data:
action: button_up_short
- choose:
- conditions: []
sequence: !input 'action_button_up_short'
default:
event_data:
- choose:
- conditions: []
- conditions: '{{ trigger_action | string in button_up_long }}'
sequence:
event_data:
action: button_up_long
- choose:
- conditions: '{{ button_up_long_loop }}'
sequence:
- repeat:
while: '{{ repeat.index < button_up_long_max_loop_repeats | int }}'
sequence: !input 'action_button_up_long'
default: !input 'action_button_up_long'
- conditions:
- '{{ trigger_action | string in button_up_release }}'
sequence:
event_data:
action: button_up_release
- choose:
- conditions: []
sequence: !input 'action_button_up_release'
- conditions: '{{ trigger_action | string in button_down_short }}'
sequence:
- choose:
- conditions: '{{ button_down_double_press }}'
sequence:
- choose:
sequence:
event_data:
action: button_down_double
- choose:
- conditions: []
sequence: !input 'action_button_down_double'
default:
- delay:
event_data:
action: button_down_short
- choose:
- conditions: []
sequence: !input 'action_button_down_short'
default:
event_data:
- choose:
- conditions: []
- conditions: '{{ trigger_action | string in button_down_long }}'
sequence:
event_data:
action: button_down_long
- choose:
- conditions: '{{ button_down_long_loop }}'
sequence:
- repeat:
while: '{{ repeat.index < button_down_long_max_loop_repeats | int }}'
sequence: !input 'action_button_down_long'
default: !input 'action_button_down_long'
- conditions:
- '{{ trigger_action | string in button_down_release }}'
sequence:
event_data:
action: button_down_release
- choose:
- conditions: []
sequence: !input 'action_button_down_release'
- conditions: '{{ trigger_action | string in button_center_short }}'
sequence:
- choose:
- conditions: '{{ button_center_double_press }}'
sequence:
- choose:
sequence:
value: >
{{ 0 | int }}
{% else %}
{% endif %}
event_data:
action: button_center_double
- choose:
- conditions: []
sequence: !input 'action_button_center_double'
default:
- delay:
event_data:
action: button_center_short
- choose:
- conditions: []
sequence: !input 'action_button_center_short'
default:
event_data:
- choose:
- conditions: []
- conditions: '{{ trigger_action | string in button_center_long }}'
sequence:
event_data:
action: button_center_long
- choose:
- conditions: []
sequence: !input 'action_button_center_long'
