Hithere,
I have a difficult usecase and I need support for getting this to work.
The RGBW controller has two channels for the RGBW stripe. With channel 1 you can control the RGB-LEDs with channel two you control the white-LEDs.
If you press the left button, you can cylce through different RGB-Colour scenes, with the right button you can toggle the white LEDs (on/off)
Now I would like to control the brighnes with the DimUp and DimDown button. This works fine for a static channel, but I do not have a clue, how i can do this depending on the selected channels…
3 scenarios are possible:
1: RGB LEDs are on: (left button was pressed)
2. White LEDs arre on: (right button was pressed)
3. both LEDs are on.
I think, only the dimmer has to be modified and must determine the status of the LEDs, and then dim either only the RGB, the white or both LEDs.
This is the actual setup. (the code for the “dropdown scene-helper” is missing)
LightScenes:
- id: red
entities:
light.gledopto_led_stripe_lena_rgb:
state: on
brightness_pct: 100
xy_color: [ 0.7291,0.2783 ]
# light.gledopto_led_stripe_lena_white:
# state: on
# brightness_pct: 1
- id: blue
entities:
state: on
brightness_pct: 100
xy_color: [ 0.136,0.04 ]
# state: on
# brightness_pct: 1
- id: orange
entities:
state: on
brightness_pct: 100
xy_color: [ 0.5841,0.4269 ]
# state: on
# brightness_pct: 1
- id: green
entities:
state: on
brightness_pct: 100
xy_color: [ 0.3154,0.5952 ]
# state: on
# brightness_pct: 1
- id: 'off'
entities:
state: off
select Scenes:
alias: Scene Selector
description: 'durchschalten der Szenen über die linke Taste der Fernbedienung'
mode: single
- platform: device
domain: mqtt
device_id: 5cdd0b1d30a5ac6908810444adc15d39
type: action
subtype: arrow_left_click
discovery_id: 0x14b457fffe431ad9 action_arrow_left_click
condition: []
- service: input_select.select_next
cycle: true
entity_id: input_select.scene_entities
- service: scene.turn_on
entity_id: "{{states('input_select.scene_entities')}}"
toggle white LEDs:
alias: ToggleWhite
description: ""
- platform: device
domain: mqtt
type: action
subtype: arrow_right_click
discovery_id: 0x14b457fffe431ad9 action_arrow_right_click
condition: []
- type: toggle
device_id: 14281426cea66207b03b10fa6a251b67
entity_id: light.gledopto_led_stripe_lena_white
domain: light
mode: single
Dimmer:
alias: Dim LED Stripe Lena
description: ''
mode: restart
- platform: device
domain: mqtt
type: action
subtype: brightness_down_hold
discovery_id: 0x14b457fffe431ad9 action_brightness_down_hold
- platform: device
domain: mqtt
type: action
subtype: brightness_up_hold
discovery_id: 0x14b457fffe431ad9 action_brightness_up_hold
- platform: device
domain: mqtt
type: action
subtype: brightness_down_release
discovery_id: 0x14b457fffe431ad9 action_brightness_down_release
- platform: device
domain: mqtt
type: action
subtype: brightness_up_release
discovery_id: 0x14b457fffe431ad9 action_brightness_up_release
condition: []
- choose:
- conditions:
- condition: trigger
sequence:
- repeat:
while:
sequence:
- device_id: 14281426cea66207b03b10fa6a251b67
domain: light
entity_id: light.gledopto_led_stripe_lena_rgb
type: brightness_increase
domain: light
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- conditions:
sequence:
- repeat:
while:
sequence:
domain: light
type: brightness_decrease
domain: light
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
