I bought three IKEA Badring water leakage sensors. One is working fine, the other two go unavailable every day.
I googled and someone suggested setting up OTA, so I put this block into configuration.yaml and restarted HA:
zha:
zigpy_config:
ota:
ikea_provider: true # Auto update Trådfri devices
ledvance_provider: false # Auto update LEDVANCE/OSRAM devices
salus_provider: false # Auto update SALUS/Computime devices
inovelli_provider: false # Auto update INOVELLI devices
thirdreality_provider: false # Auto update 3REALITY devices
#otau_directory: /path/to/your/ota/folder # Utilize .ota files to update everything else
Seems no updates were available:
IKEA BADRING Water Leakage Sensor Firmware
36 minutes ago
Last changed:36 minutes ago
Last updated:36 minutes ago
Up-to-date
Installed version: 0x01000007
Latest version: 0x01000007
Good point. I originally discounted that since I have another device (Aquara reed switch) at almost the exact same spot the Badring is at, which has no issues, but yea, I’m trying now.
I switched places of the one working Badring with the always unavailable one, and put the other unavailable one like 30cm next to the skyconnect.
I will report tomorrow or as soon as one becomes unavailable again.
Hi, I think I figured out how to keep IKEA Badring sensor available to HA. I have made simple automation which presses “identify” button every five minutes.
Without is, if falls to unavailable mode every couple of hours. Now it’s been two days and the sensor keeps online the whole time.
UPDATE: Since adding the Button press of Identify, the device has stayed online for the last 24 hours. I changed mine to every 15 minutes vs every 5 minutes as my device wasn’t going offline that quickly.
UPDATE 2: Still going offline, even after an every 5 minute button press. Re-paired it to the Ikea Air Purifier I have to see if connecting that way is better. It’s not too far away from other Zigbee devices, so not sure why it keeps disconnecting.
I seem to have the exact same problem as you. It gets through the interview but never gets past the configuration stage. Did you manage to solve it yet?
I bought three Badrings, all have the same problem. Going offline after few hours, sometimes they wake up by themeselves after a few next hours. What wakes them up instantly is shorting sensor pins (=simulating water leakage). I have device availability enabled in Z2M if that matters.
Certainly not a signal strength issue, all have a router not further away than 2 meters in straight line (or their sensitivity is that terrible ?).
I returned all three of them and now will give a try to Sonoff water leakage sensors.
Adding them to Z2M was also a bit of a challenge because they go to suspend mode just after 3 seconds after addition to Z2M and this is usually insufficent to finish device configuration by Z2M. Yes, there is an option to extend identity timeout but you cannot change it if device did not finish configuration.
I bought one Badring as an experiment (I have lots of Aqara & Tuya). It is placed right next to an Ikea smart plug. When it is on-line, it has an LQI between 130 & 180. It comes on-line once per day for 6 hours (+/- 5 minutes).
It establishes a timing pattern for a few days - eg on-line at 6pm (roughly) and off-line at midnight (roughly). Prior to that it was on-line at 10pm and off-line at 4am for a few about 6 days, etc.
This is not random behaviour! (but it seems no-one has a solution - maybe I’ll complain to Ikea !)
Did you find a solution? My sensor has the same behavior, disconnecting regularly and waking up every day for approx. 6 hours before disconnecting again. Seems like having a pattern, that is strange.
