IKEA Bilresa Dual Button Light Control with Smooth Dimming
A Blueprint to quickly and easily set up a Bilresa dual button to control a light or light group.
The Press and Hold dimming lets the hardware handle the transition. This results in the dimming being smooth and responsive while avoiding the stuttering that comes with other approaches such as looping light on commands.
This feature does require the light selected to support transitions and so it may not work as expected on some devices.
Installation:
Source on GitHub: HA-Blueprints/IKEA/IKEA_Bilresa_Dual_Button.yaml at main · Kaito-Mez/HA-Blueprints · GitHub
Configuration:
  • Single Presses turn the light(s) on/off.
  • Double Presses and Press and Holds can be configured to either adjust brightness or trigger custom actions.
  • Double Press brightness control steps the brightness up or down by a configurable percentage.
  • Press and Hold brightness control smoothly brightens or dims the light while the button is held, the speed can be configured. There are also options to help compensate for issues that arise due to latency.
Please feel free to leave any feedback you have or suggest improvements!
I find the approach interesting to work around missing HA features, although ideally it should not be needed: Zigbee and Matter lights have native move / stop commands to start the dimming and stop the dimming so no need to track time or levels.
In Zigbee lights using Z2M it’s easy since there’s a brightness_move action (with speed 0 to stop) so just calling brightness_move(60) to increase, or -60 to decrease, in the automation when long pressed and brightness_move(0) when released is enough, the light does everything.
In Matter, the HA integration does not expose the move/stop commands so can’t be used without tinkering with the core integration. While I’ve not tested the blueprint, conceptually it’s way better than a loop repeating steps and a good workaround for the lack of move/stop actions in the automations.
This Blueprint is working lovely and is such a huge improvement in comparison to my old approach to double click for increasing/deacreasing the brighness.
My only concern is that the Bilresa remotes are still occasionally losing their connection (huge topic in the matterjs server Github) and become unavailable in HA. As soon as they come back online, the last button click is “re-triggert” and my lights turn on/off again. This should be the same issue as described here: IKEA BILRESA Matter Button 👈 [Blueprint] for Ikea *Matter over Thread* Button (Actions, Scripts, and Entities)! - #12 by josvink66
Probably the same solution would apply. Can you provide a fixed version?
@joshi1 I had this happen to me a couple times but hadn’t had a chance to look into the cause yet, so thanks a lot!
I’ve made the suggested changes now, so re-import it and give it a go.
