Beginner warning: I’ve built a hass.io server on a spare rPi, and seemingly have setup zigbee2mqtt & Mosquitto broker. I’ve ‘believe’ I’ve managed to pair TRADFRI driver for wireless control (30 watt), from what I can see in the logs, but I don’t see any devices within ‘Configuration > Integration’
Any ideas?
Here’s the zigbee2mqtt logs:
[Info] Configuration file found: /share/zigbee2mqtt/configuration.yaml
[Info] Configuration written to /share/zigbee2mqtt/configuration.yaml
2019-08-01T13:53:25: PM2 log: Launching in no daemon mode
2019-08-01T13:53:26: PM2 log: App [npm:0] starting in -fork mode-
2019-08-01T13:53:26: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.4.0
> node index.js
zigbee2mqtt:info 8/1/2019, 1:53:33 PM Logging to directory: '/share/zigbee2mqtt/log/2019-08-01.13-53-33'
zigbee2mqtt:info 8/1/2019, 1:53:35 PM Starting zigbee2mqtt version 1.4.0 (commit #unknown)
zigbee2mqtt:info 8/1/2019, 1:53:35 PM Starting zigbee-shepherd
zigbee2mqtt:info 8/1/2019, 1:53:37 PM zigbee-shepherd started
zigbee2mqtt:info 8/1/2019, 1:53:37 PM Coordinator firmware version: '20190425'
zigbee2mqtt:info 8/1/2019, 1:53:37 PM Currently 1 devices are joined:
zigbee2mqtt:info 8/1/2019, 1:53:37 PM 0x90fd9ffffe1f3680 (0x90fd9ffffe1f3680): ICPSHC24-30EU-IL-1 - IKEA TRADFRI driver for wireless control (30 watt) (Router)
zigbee2mqtt:warn 8/1/2019, 1:53:37 PM `permit_join` set to `true` in configuration.yaml.
zigbee2mqtt:warn 8/1/2019, 1:53:37 PM Allowing new devices to join.
zigbee2mqtt:warn 8/1/2019, 1:53:37 PM Set `permit_join` to `false` once you joined all devices.
zigbee2mqtt:info 8/1/2019, 1:53:37 PM Zigbee: allowing new devices to join.
zigbee2mqtt:info 8/1/2019, 1:53:37 PM Connecting to MQTT server at mqtt://homeassistant
zigbee2mqtt:info 8/1/2019, 1:53:38 PM zigbee-shepherd ready
zigbee2mqtt:info 8/1/2019, 1:53:40 PM Connected to MQTT server
zigbee2mqtt:info 8/1/2019, 1:53:40 PM MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info 8/1/2019, 1:53:40 PM MQTT publish: topic 'zigbee2mqtt/0x90fd9ffffe1f3680', payload '{"state":"ON","linkquality":173,"brightness":254}'
zigbee2mqtt:info 8/1/2019, 1:53:40 PM MQTT publish: topic 'homeassistant/light/0x90fd9ffffe1f3680/light/config', payload '{"brightness":true,"schema":"json","command_topic":"zigbee2mqtt/0x90fd9ffffe1f3680/set","state_topic":"zigbee2mqtt/0x90fd9ffffe1f3680","name":"0x90fd9ffffe1f3680_light","unique_id":"0x90fd9ffffe1f3680_light_zigbee2mqtt","device":{"identifiers":"zigbee2mqtt_0x90fd9ffffe1f3680","name":"0x90fd9ffffe1f3680","sw_version":"Zigbee2mqtt 1.4.0","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info 8/1/2019, 1:53:40 PM MQTT publish: topic 'homeassistant/sensor/0x90fd9ffffe1f3680/linkquality/config', payload '{"unit_of_measurement":"-","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x90fd9ffffe1f3680","json_attributes_topic":"zigbee2mqtt/0x90fd9ffffe1f3680","name":"0x90fd9ffffe1f3680_linkquality","unique_id":"0x90fd9ffffe1f3680_linkquality_zigbee2mqtt","device":{"identifiers":"zigbee2mqtt_0x90fd9ffffe1f3680","name":"0x90fd9ffffe1f3680","sw_version":"Zigbee2mqtt 1.4.0","model":"TRADFRI driver for wireless control (30 watt) (ICPSHC24-30EU-IL-1)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info 8/1/2019, 1:53:40 PM MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.4.0","commit":"unknown","coordinator":20190425,"log_level":"info","permit_join":true}'
zigbee2mqtt:info 8/1/2019, 1:56:58 PM Succesfully reenabled joining
Its config file:
devices:
'0x90fd9ffffe1f3680':
friendly_name: '0x90fd9ffffe1f3680'
retain: false
'0xd0cf5efffec08c3b':
friendly_name: '0xd0cf5efffec08c3b'
retain: false
homeassistant: true
mqtt:
base_topic: zigbee2mqtt
password: MQTTUser
server: mqtt://homeassistant
user: MQTTUser
permit_join: true
serial:
port: /dev/ttyACM0
I’ve seen this other page on manually adding devices but not sure where I’d put the config code. https://www.zigbee2mqtt.io/devices/ICPSHC24-30EU-IL-1
