Ikea Devices and the Update function in Home Assistant- buttons greyed out
Core
2023.11.1
Supervisor
2023.10.1
Operating System
11.1
Frontend
20231030.1
So this morning I see there is something on the notification tab on my dashboard, it was updates for 2 Ikea buttons and 3 blinds. Not unusual and since they never update I normally just skip them. This time however they were already spinning trying to update and both the update button and skip button were greyed out. I did not click any of it. I rebooted HA, I restarted it I went into Z2M and checked do not do auto updates I even restarted in safe mode still no love. I then just completely shut it down, unplugged and re plugged it, same problem?? Anyone have any idea what is going on and how to remedy this?
Did you find a solution for this? I have the same problem…
I’m using zigbee2mqtt so I suspect it has something to do with that.
Sorry I don’t check the forums enough. If you still are having the issue, which I assume you are not this will be for anyone else that might run into this. I am 90% sure the Z2M update did not install correctly so I just restored the back up at the point I knew it was all OK which corrected the problem, re did the update once it appeared again and problem was no more!
