I’ve been using Ikea smart blinds FYRTUR and accompanied remote via Smartthings in HA for a while now. All works great. Recently I’ve decided to move from Smartthings for my zigbee devices to SkyConnect.
After setting up SkyConnect in HA, I’ve reset my blinds and remote and connected them to HA via SkyConnect service. Technically it all works; I am able to control the blinds from HA. But previously the remote was also linked to the blinds and I was able to control them via remote as well. This is no longer the case. Moreover, the remote in HA is not registered as a button, so I can’t even programme it to close/open blinds via HA.
Does anyone know how I can have the remote linked to both the blinds and HA? I’ve tried regular pairing, but it doesn’t seem to work any more.
There are Blueprints available for the IKEA remote. They enable you to control the blinds or anything else you want.
Thanks! I am going to go check for some blueprints. In the meantime, I have discovered “zha_event” and made an automation for my remote.
Should really spend more time googling before asking question.
I have the same problem, occurred simultaneously with the switch to SkyConnect. When I re-pair the Ikea remot, I can sometimes register the keystroke once, then the remote drops out of the network.
ps: I already use a blueprint, which worked fine until before the change.
