I have a fyrtur blind paired to DeConz and HA. It mostly works perfectly except one annoying problem which is very difficult to debug.
Around 1 in 10 times, the blind doesn’t open completely. It stops after just a couple of centimeters (maybe 3-5 cm). It is opening just for a second or two before it stops.
It looks that the problem only happens when the blind is opened through an automation which is triggered automatically in the morning. I didn’t see it happen when opening via a button, but it can just be a coincidence.
I am using the cover.open_cover
service to open the blind. Other than that there is no action in the automation.
This a trace of an automation run which didn’t fully open the blind. As you can see, there is nothing suspicious:
The automation code is very simple:
alias: 'WAKE UP: Open blinds'
description: ''
- platform: state
entity_id: calendar.waking_up_calendar
to: 'on'
condition:
- condition: state
state: Waking up (just blinds)
attribute: message
- service: cover.open_cover
device_id: 7e3a69a5e68bdbb9999973be9ed84279
mode: single
There is nothing in the logs or logbook.
Any idea what can be going wrong here? Or how to debug this problem?
EDIT: Found a similar problem reported on reddit. They suggest it’s the hardware problem which I didn’t consider, because it only happens infrequently… hmm.
