Is it possible to add a switch in the Ikea integration to remotely reboot the Hub? This option seems to be available in the pytradfri api
The hub become unresponsive or slow after a week or so. A scheduled nightly reboot would solve the problem
I’m also interested in this, being able to reboot the Tradfri remotely would be great
The easiest way is probably put a Wemo switch or TP-link switch between hub and outlet. Then you can create an automation that reboots the hub every week and if necessary you can create a switch to do it manually.
