Some more information. This is from logfile, when I added the motion sensors.
A lot of failures in the log but HA tells me it went wll.
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=3, profile_id=0, cluster_id=32822, data=Serialized[b'\x03\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
[0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_rsp: [<Status.SUCCESS: 0>]
[0x0000:zdo] No handler for ZDO request:ZDOCmd.Mgmt_Permit_Joining_rsp([<Status.SUCCESS: 0>])
Sending 'zdo_leave_req' failed:
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.Broadcast: 15>, address=<BroadcastAddress.ALL_ROUTERS_AND_COORDINATOR: 65532>), dst_ep=0, source_route=None, extended_timeout=False, tsn=129, profile_id=0, cluster_id=19, data=Serialized[b'\x81!r\xdf\xfdB\xfe\xffW\xb4\x14\x80'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
New device 0x7221 (14:b4:57:ff:fe:42:fd:df) joined the network
[0x7221] Scheduling initialization
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7221 ieee=14:b4:57:ff:fe:42:fd:df is_initialized=False> from ep 0 to ep 0, cluster 19: b'\x81!r\xdf\xfdB\xfe\xffW\xb4\x14\x80'
[0x7221:zdo] ZDO request ZDOCmd.Device_annce: [0x7221, 14:b4:57:ff:fe:42:fd:df, 128]
Tries remaining: 3
[0x7221] Requesting 'Node Descriptor'
Tries remaining: 2
[0x7221] Extending timeout for 0x13 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=19, profile_id=0, cluster_id=32770, data=Serialized[b'\x13\x00!r\x02@\x80|\x11RR\x00\x00,R\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7221 ieee=14:b4:57:ff:fe:42:fd:df is_initialized=False> from ep 0 to ep 0, cluster 32770: b'\x13\x00!r\x02@\x80|\x11RR\x00\x00,R\x00\x00'
[0x7221] Got Node Descriptor: NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4476, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)
[0x7221] Discovering endpoints
Tries remaining: 3
[0x7221] Extending timeout for 0x14 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=20, profile_id=0, cluster_id=32773, data=Serialized[b'\x14\x00!r\x01\x01'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7221 ieee=14:b4:57:ff:fe:42:fd:df is_initialized=False> from ep 0 to ep 0, cluster 32773: b'\x14\x00!r\x01\x01'
[0x7221] Discovered endpoints: [1]
[0x7221] Initializing endpoints [<Endpoint id=1 in=[] out=[] status=<Status.NEW: 0>>]
[0x7221:1] Discovering endpoint information
Tries remaining: 3
[0x7221] Extending timeout for 0x15 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=21, profile_id=0, cluster_id=32772, data=Serialized[b'\x15\x00!r"\x01\x04\x01P\x08\x01\x07\x00\x00\x01\x00\x03\x00\t\x00 \x00\x00\x10|\xfc\x06\x03\x00\x04\x00\x06\x00\x08\x00\x19\x00\x00\x10'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
Received frame on uninitialized device <Device model=None manuf=None nwk=0x7221 ieee=14:b4:57:ff:fe:42:fd:df is_initialized=False> from ep 0 to ep 0, cluster 32772: b'\x15\x00!r"\x01\x04\x01P\x08\x01\x07\x00\x00\x01\x00\x03\x00\t\x00 \x00\x00\x10|\xfc\x06\x03\x00\x04\x00\x06\x00\x08\x00\x19\x00\x00\x10'
[0x7221:1] Discovered endpoint information: SizePrefixedSimpleDescriptor(endpoint=1, profile=260, device_type=2128, device_version=1, input_clusters=[0, 1, 3, 9, 32, 4096, 64636], output_clusters=[3, 4, 6, 8, 25, 4096])
[0x7221:1:0x0000] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=22, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7221:1:0x0000] Sending request: Read_Attributes(attribute_ids=[4, 5])
[0x7221] Extending timeout for 0x16 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=0, data=Serialized[b'\x18\x16\x01\x04\x00\x00B\x0eIKEA of Sweden\x05\x00\x00B\x15TRADFRI motion sensor'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=178, rssi=None)
[0x7221:1:0x0000] Received ZCL frame: b'\x18\x16\x01\x04\x00\x00B\x0eIKEA of Sweden\x05\x00\x00B\x15TRADFRI motion sensor'
[0x7221:1:0x0000] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=22, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0000] Decoded ZCL frame: Basic:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0004, status=<Status.SUCCESS: 0>, value=TypeValue(type=CharacterString, value='IKEA of Sweden')), ReadAttributeRecord(attrid=0x0005, status=<Status.SUCCESS: 0>, value=TypeValue(type=CharacterString, value='TRADFRI motion sensor'))])
[0x7221] Read model 'TRADFRI motion sensor' and manufacturer 'IKEA of Sweden' from <Endpoint id=1 in=[basic:0x0000, power:0x0001, identify:0x0003, alarms:0x0009, poll_control:0x0020, lightlink:0x1000, manufacturer_specific:0xFC7C] out=[identify:0x0003, groups:0x0004, on_off:0x0006, level:0x0008, ota:0x0019, lightlink:0x1000] status=<Status.ZDO_INIT: 1>>
[0x7221] Discovered basic device information for <Device model='TRADFRI motion sensor' manuf='IKEA of Sweden' nwk=0x7221 ieee=14:b4:57:ff:fe:42:fd:df is_initialized=True>
Device is initialized <Device model='TRADFRI motion sensor' manuf='IKEA of Sweden' nwk=0x7221 ieee=14:b4:57:ff:fe:42:fd:df is_initialized=True>
Checking quirks for IKEA of Sweden TRADFRI motion sensor (14:b4:57:ff:fe:42:fd:df)
Considering <class 'zhaquirks.ikea.motionzha.IkeaTradfriMotionE1745'>
Found custom device replacement for 14:b4:57:ff:fe:42:fd:df: <class 'zhaquirks.ikea.motionzha.IkeaTradfriMotionE1745'>
'button' component -> 'ZHAIdentifyButton' using ['identify']
'sensor' component -> 'Battery' using ['power']
'sensor' component -> 'RSSISensor' using ['basic']
'sensor' component -> 'LQISensor' using ['basic']
device - 0x7221:14:b4:57:ff:fe:42:fd:df entering async_device_initialized - is_new_join: True
device - 0x7221:14:b4:57:ff:fe:42:fd:df has joined the ZHA zigbee network
[0x7221](TRADFRI motion sensor): started configuration
[0x7221:ZDO](TRADFRI motion sensor): 'async_configure' stage succeeded
[0x7221:1:0x0003]: Configuring cluster attribute reporting
Error handling '_save_attribute' event with (14:b4:57:ff:fe:42:fd:df, 1, 0, 4, 'IKEA of Sweden') params: FOREIGN KEY constraint failed
Error handling '_save_attribute' event with (14:b4:57:ff:fe:42:fd:df, 1, 0, 5, 'TRADFRI motion sensor') params: FOREIGN KEY constraint failed
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=4096, data=Serialized[b'\x19\x18A\x01\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=178, rssi=None)
[0x7221:1:0x1000] Received ZCL frame: b'\x19\x18A\x01\x00\x00'
[0x7221:1:0x1000] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=True, *is_general=False, *is_reply=True), tsn=24, command_id=65, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x1000] Decoded ZCL frame: LightLinkCluster:get_group_identifiers_rsp(total=1, start_index=0, group_info_records=[])
[0x0000:2] Cannot add 0x0000 group, no groups cluster
[0x0000:1] Cannot add 0x0000 group, no groups cluster
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=0, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=0, source_route=None, extended_timeout=False, tsn=23, profile_id=0, cluster_id=32801, data=Serialized[b'\x17\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=0, non_member_radius=0, lqi=None, rssi=None)
[0x7221:1:0x0001]: bound 'power' cluster: Status.SUCCESS
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=1, data=Serialized[b'\x08\x1d\x07\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=178, rssi=None)
[0x7221:1:0x0001] Received ZCL frame: b'\x08\x1d\x07\x00'
[0x7221:1:0x0001] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=29, command_id=7, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0001] Decoded ZCL frame: PowerConfiguration2CRCluster:Configure_Reporting_rsp(status_records=[ConfigureReportingResponseRecord(status=<Status.SUCCESS: 0>)])
[0x7221:1:0x0001]: Successfully configured reporting for '{'battery_voltage': (3600, 10800, 1), 'battery_percentage_remaining': (3600, 10800, 1)}' on 'power' cluster: [ConfigureReportingResponseRecord(status=<Status.SUCCESS: 0>)]
[0x7221:1:0x0020]: Failed to bind 'poll_control' cluster:
[0x7221:1:0x0006]: Failed to bind 'on_off' cluster:
[0x7221:1:0x0008]: Failed to bind 'level' cluster:
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=6, data=Serialized[b'\x01\x02B\x00\x08\x07\x00\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=11, non_member_radius=0, lqi=189, rssi=None)
[0x7221:1:0x0006] Received ZCL frame: b'\x01\x02B\x00\x08\x07\x00\x00'
[0x7221:1:0x0006] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=False), tsn=2, command_id=66, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7221:1:0x0006] Decoded ZCL frame: OnOff:on_with_timed_off(on_off_control=<OnOffControl.0: 0>, on_time=1800, off_wait_time=0)
[0x7221:1:0x0006] Received command 0x42 (TSN 2): on_with_timed_off(on_off_control=<OnOffControl.0: 0>, on_time=1800, off_wait_time=0)
[0x7221:1:0x0006] No explicit handler for cluster command 0x42: on_with_timed_off(on_off_control=<OnOffControl.0: 0>, on_time=1800, off_wait_time=0)
[0x7221:1:0x0006]: received 'on_with_timed_off' command with on_with_timed_off(on_off_control=<OnOffControl.0: 0>, on_time=1800, off_wait_time=0) args on cluster_id '6' tsn '2'
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=32, data=Serialized[b'\x18\x1e\x04\x00'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=189, rssi=None)
[0x7221:1:0x0020] Received ZCL frame: b'\x18\x1e\x04\x00'
[0x7221:1:0x0020] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=30, command_id=4, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0020] Decoded ZCL frame: PollControl:Write_Attributes_rsp(status_records=[WriteAttributesStatusRecord(status=<Status.SUCCESS: 0>)])
[0x7221:1:0x0020]: 3300.0s check-in interval set: Write_Attributes_rsp(status_records=[WriteAttributesStatusRecord(status=<Status.SUCCESS: 0>)])
[0x7221:1:0x0020]: finished channel configuration
[0x7221:1:0x0003]: 'async_configure' stage succeeded
[0x7221:1:0x0000]: 'async_configure' stage succeeded
[0x7221:1:0x0001]: 'async_configure' stage succeeded
[0x7221:1:0x1000]: 'async_configure' stage succeeded
[0x7221:1:0x0020]: 'async_configure' stage succeeded
[0x7221:1:0x0006]: 'async_configure' stage succeeded
[0x7221:1:0x0008]: 'async_configure' stage succeeded
[0x7221:1:0x0019]: 'async_configure' stage succeeded
[0x7221](TRADFRI motion sensor): completed configuration
[0x7221:1:0x0003] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.CLUSTER_COMMAND: 1>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=True, *is_general=False, *is_reply=False), tsn=31, command_id=64, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7221:1:0x0003] Sending request: trigger_effect(effect_id=<EffectIdentifier.Okay: 2>, effect_variant=<EffectVariant.Default: 0>)
[0x7221] Extending timeout for 0x1f request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=3, data=Serialized[b'\x08\x1f\x0b@\x81'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=189, rssi=None)
[0x7221:1:0x0003] Received ZCL frame: b'\x08\x1f\x0b@\x81'
[0x7221:1:0x0003] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=31, command_id=11, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0003] Decoded ZCL frame: Identify:Default_Response(command_id=64, status=<Status.UNSUP_CLUSTER_COMMAND: 129>)
[0x7221:1:0x0003]: executed 'trigger_effect' command with args: '()' kwargs: '{'effect_id': <EffectIdentifier.Okay: 2>, 'effect_variant': <EffectVariant.Default: 0>}' result: Default_Response(command_id=64, status=<Status.UNSUP_CLUSTER_COMMAND: 129>)
[0x7221](TRADFRI motion sensor): started initialization
[0x7221:ZDO](TRADFRI motion sensor): 'async_initialize' stage succeeded
[0x7221:1:0x0003]: initializing channel: from_cache: False
[0x7221:1:0x0003]: finished channel initialization
[0x7221:1:0x0000]: initializing channel: from_cache: False
[0x7221:1:0x0000]: finished channel initialization
[0x7221:1:0x0001]: initializing channel: from_cache: False
[0x7221:1:0x0001]: initializing uncached channel attributes: ['battery_voltage', 'battery_percentage_remaining'] - from cache[False]
[0x7221:1:0x0001]: Reading attributes in chunks: ['battery_voltage', 'battery_percentage_remaining']
[0x7221:1:0x0001] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Server_to_Client: 0>, disable_default_response=0, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=32, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7221:1:0x0001] Sending request: Read_Attributes(attribute_ids=[32, 33])
[0x7221] Extending timeout for 0x20 request
[0x7221:1:0x1000]: initializing channel: from_cache: False
[0x7221:1:0x1000]: finished channel initialization
[0x7221:1:0x0020]: initializing channel: from_cache: False
[0x7221:1:0x0020]: finished channel initialization
[0x7221:1:0x0006]: initializing channel: from_cache: False
[0x7221:1:0x0006]: initializing cached channel attributes: ['start_up_on_off']
[0x7221:1:0x0006]: Reading attributes in chunks: ['start_up_on_off']
[0x7221:1:0x0006] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=33, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0006] Sending request: Read_Attributes(attribute_ids=[16387])
[0x7221] Extending timeout for 0x21 request
[0x7221:1:0x0008]: initializing channel: from_cache: False
[0x7221:1:0x0008]: finished channel initialization
[0x7221:1:0x0006]: finished channel initialization
[0x7221:1:0x0019]: initializing channel: from_cache: False
[0x7221:1:0x0019]: finished channel initialization
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=1, data=Serialized[b'\x18 \x01 \x00\x00 \x1b!\x00\x00 /'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=189, rssi=None)
[0x7221:1:0x0001] Received ZCL frame: b'\x18 \x01 \x00\x00 \x1b!\x00\x00 /'
[0x7221:1:0x0001] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=32, command_id=1, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0001] Decoded ZCL frame: PowerConfiguration2CRCluster:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0020, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint8_t, value=27)), ReadAttributeRecord(attrid=0x0021, status=<Status.SUCCESS: 0>, value=TypeValue(type=uint8_t, value=47))])
[0x7221:1:0x0001]: Performing channel specific initialization: ['battery_voltage', 'battery_percentage_remaining']
[0x7221:1:0x0001]: Reading attributes in chunks: ['battery_size', 'battery_quantity']
[0x7221:1:0x0001]: finished channel initialization
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=6, data=Serialized[b'\x10!\x01\x03@\x86'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=193, rssi=None)
[0x7221:1:0x0006] Received ZCL frame: b'\x10!\x01\x03@\x86'
[0x7221:1:0x0006] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=33, command_id=1, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7221:1:0x0006] Decoded ZCL frame: OnOff:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x4003, status=<Status.UNSUPPORTED_ATTRIBUTE: 134>)])
[0x7221:1:0x0006]: initializing uncached channel attributes: ['on_off'] - from cache[False]
[0x7221:1:0x0006]: Reading attributes in chunks: ['on_off']
[0x7221:1:0x0006] Sending request header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=False, direction=<Direction.Client_to_Server: 1>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=True), tsn=34, command_id=<GeneralCommand.Read_Attributes: 0>, *direction=<Direction.Client_to_Server: 1>, *is_reply=True)
[0x7221:1:0x0006] Sending request: Read_Attributes(attribute_ids=[0])
[0x7221] Extending timeout for 0x22 request
Received a packet: ZigbeePacket(src=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x7221), src_ep=1, dst=AddrModeAddress(addr_mode=<AddrMode.NWK: 2>, address=0x0000), dst_ep=1, source_route=None, extended_timeout=False, tsn=0, profile_id=260, cluster_id=6, data=Serialized[b'\x10"\x01\x00\x00\x86'], tx_options=<TransmitOptions.NONE: 0>, radius=29, non_member_radius=0, lqi=189, rssi=None)
[0x7221:1:0x0006] Received ZCL frame: b'\x10"\x01\x00\x00\x86'
[0x7221:1:0x0006] Decoded ZCL frame header: ZCLHeader(frame_control=FrameControl(frame_type=<FrameType.GLOBAL_COMMAND: 0>, is_manufacturer_specific=0, direction=<Direction.Server_to_Client: 0>, disable_default_response=1, reserved=0, *is_cluster=False, *is_general=True, *is_reply=False), tsn=34, command_id=1, *direction=<Direction.Server_to_Client: 0>, *is_reply=False)
[0x7221:1:0x0006] Decoded ZCL frame: OnOff:Read_Attributes_rsp(status_records=[ReadAttributeRecord(attrid=0x0000, status=<Status.UNSUPPORTED_ATTRIBUTE: 134>)])
[0x7221:1:0x0003]: 'async_initialize' stage succeeded
[0x7221:1:0x0000]: 'async_initialize' stage succeeded
[0x7221:1:0x0001]: 'async_initialize' stage succeeded
[0x7221:1:0x1000]: 'async_initialize' stage succeeded
[0x7221:1:0x0020]: 'async_initialize' stage succeeded
[0x7221:1:0x0006]: 'async_initialize' stage succeeded
[0x7221:1:0x0008]: 'async_initialize' stage succeeded
[0x7221:1:0x0019]: 'async_initialize' stage succeeded
[0x7221](TRADFRI motion sensor): power source: Battery or Unknown
[0x7221](TRADFRI motion sensor): completed initialization
[0x7221](TRADFRI motion sensor): Device seen - marking the device available and resetting counter
[0x7221](TRADFRI motion sensor): Update device availability - device available: True - new availability: True - changed: False
