Ikea on/off button
hi I have an Ikea on / off button which is connected to HA. I can get the Ikea button to turn the light on and off and turn it up and down, but when I turn the light off and on again Then it sets the bulb to 1% some who can help
When you call the service to turn on the light you can also set the brightness to 100%:
  - service: light.turn_on
      brightness_pct: 100
      entity_id: light.garage_zgroup_zha_group_0x0002
mode: single
it is a blueprint
Then edit the blueprint to add the data…
blueprint:
  name: ZHA - IKEA Tradfri on/off switch
  description: '"Control your light(s) with IKEA Tradfri on/off switch
    Select the Tradfri remote and your lights.
    You can turn the lights On / Off, or hold the buttons to dim the lights"
  domain: automation
  input:
    remote:
      description: The remote that will control the lights
      selector:
        device:
          integration: zha
          manufacturer: IKEA of Sweden
          model: TRADFRI on/off switch
    light:
      description: The lights that will be controlled
      selector:
          entity:
            domain: light
  source_url: https://community.home-assistant.io/t/zha-ikea-tradfri-on-off-switch-incl-dimmer/255412
mode: restart
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input "remote"
  - variables:
      command: "{{ trigger.event.data.command }}"
      cluster_id: "{{ trigger.event.data.cluster_id }}"
      endpoint_id: "{{ trigger.event.data.endpoint_id }}"
  - choose:
      - conditions:
          - "{{ command == 'on' }}"
          - "{{ cluster_id == 6 }}"
          - "{{ endpoint_id == 1 }}"
        sequence:
            target: !input "light"
              transition: 1
      - conditions:
          - "{{ command == 'off' }}"
        sequence:
          - service: light.turn_off
              transition: 1
      - conditions:
          - "{{ command == 'move_with_on_off' }}"
          - "{{ cluster_id == 8 }}"
        sequence:
          repeat:
            while:
              - condition: template
                value_template: "{{ repeat.index < 10 }}"
            sequence:
                  transition: 1
                  brightness_step_pct: 60
              - delay: 1
      - conditions:
          - "{{ command == 'move' }}"
        sequence:
          repeat:
            while:
            sequence:
                  transition: 1
                  brightness_step_pct: -30
              - delay: 1
      - conditions:
          - "{{ command == 'stop' }}"
        sequence:
this is the code, what should i change?
i want it to use last used brightness
Doesn’t that depend on your Zigbee driver?
