Sinds last update of HA to 2025.1 the ikea remote doesn’t work anymore.
In node red the sensor.remote_action is not there anymore.
In Zigbee2mqtt its show good with indentify the action are all there.
Same here. They don’t work anymore. Zigbee2MQTT works fine, had an update too.
My Zigbee2mqtt works also good.
As you can see the battery state is showing in nodred.
Wil there be a update for this?
I hoop so, because the ikea remotes are great.
Z2M 2.0:
Lookt at it.
But a lot of the devices dorsnt have an device-id.
Somebody having a explenation how to ad a device-id to a zigbee device.
And how to ad it to mqtt.
As a quick fix you can add in z2m config:
homeassistant:
legacy_action_sensor: true
If you’re using Zigbee2MQTT version 2.0, enable “Home Assistant legacy action sensors”. By default, version 2.0 eliminated all sensor.xxxxx_action` entities.
Thanks,
This was the solution for now I think.
You’re welcome!
Please consider marking my post above with the Solution tag. It will automatically place a check-mark next to the topic’s title which indicates to others that the topic has been solved. This helps users find answers to similar questions.
For more information about the Solution tag, refer to guideline 21 in the FAQ.
I think it would be best not to use the legacy or experimental feature and use the recommended MQTT device trigger
just use something like this:
- trigger: mqtt
topic: zigbee2mqtt/Ikea Styrbar/action
enabled: true
payload: arrow_right_click
or this:
- domain: mqtt
device_id: 414697fe1f182dbee46c8964f3771be4
type: action
subtype: arrow_right_click
trigger: device
Thanks.
just found out where i can find de device-ids.
Finaly this wil be the only way i think.
I now just dont now where to put programming wich you advice.
In configuration.yaml
Or
In automatation?
For now the legacy works, but for how long is the big question ![]()
well you will have to replace the outdated action sensors (see Home Assistant action sensor (deprecated)) in all your automations
so get rid of this:
triggers:
- trigger: state
entity_id: sensor.ikea_styrbar_action
and replace through the variants mentioned above
Looks like for Node Read atomations there is no solution rather than sticking with legacy_action_sensor: true: How to use Node-RED with MQTT device trigger from Zigbee2MQTT 2.0.0 breaking change? · Koenkk/zigbee2mqtt · Discussion #25579 · GitHub
