HA beginner here. Running 2022.11.0 front end 20221207.0 -latest via docker container on RPi 4.
I’ve managed to automate lights via sunrise and sunset and the IKEA parts are discovered and I can manually switch and change everything, brightness, CCT and RGB. However, I’m banging my head against a wall when it comes to CCT or RGB(WW) changes via automation. All examples I’ve found seems to use very different syntax than what’s created via “create automation”.
End goal here is to trigger color change based on electricity price to give my parents a visual indicator of when is a good time to start dishwasher, washing machine and tumble dryer without opening an app or web page.
Trigger on price works as intended, but somehow I’m only able to turn on/off and change brightness.
For example, this works:
alias: Electricity > 5 kr/kWh
description: Electricity is expensive
- type: value
platform: device
device_id: df257d44b4e11f9041a68ea866f071f3
entity_id: sensor.nordpool_kwh_se3_sek_3_10_025
domain: sensor
above: 5
condition: []
- type: turn_on
device_id: 075943509147aced97bdd27d1239d490
entity_id: light.rgbw_matplats
domain: light
brightness_pct: 10
mode: single
However, if I try to add a new line after brightness_pct or change it to for example:
rgbww_color: [100,100,100,100,100]
Gives “Message malformed: extra keys not allowed @ data[‘rgbww_color’] error message. Same for rgb and rgbw.
Examples I find here and around the web uses to me very different syntax with service and data_template, so I’m lost.
Am I able to use the automatically generated automation scripts to change anything but on/off or brightness?
Thanks in advance!
