Having nothing but issues with the IKEA blind intialy it worked fine from what I remember but now I’m getting these two issues
when the blind is controlled after it’s been idle for a while it can take up to 10 seconds before it starts moving. Once its moving it react for a about 5inutes instantly. This issue was not present when I first used the blind with HA.
When the blind has not been used for a while and it received a command for up or down it starts moving then stops after about 10cm. You then need to re issue the command to get it to finish. This issues seems to come and go in blocks.
Pretty much very unreliable. Worked perfectly for months with ST.
