IKEA Smart Lighting (Zigbee)
I suspect it still works, but I had a nightmare with it - lights dropping off the app, not being to get anything to work consistently, etc. I took some bulbs back and got a couple of replacements with remotes and that didn’t seem to help much, even after factory resets.
Eventually, I took the hub back and replaced it with a new one (a little cheeky as it was my messing around that seems to have caused it to go a bit mad) and that has worked out nicely. My main problem is that the modules seem to be taking forever to load and causing all sorts of errors. I’m trying to sort them out, but will post back if I can’t fix it.
Long story short: Just get at least one bulb/remote set - you can use the remote to pair all your bulbs and then move them over to new groups. It may be possible to do without a remote, but it doesn’t seem worth all the time and hassle.
I wonder after reading the news that IKEA’s products will integrate with both the Mi Home app and the Xiao AI assistant:
Will it be possible to connect Xiaomi products with IKEA hub? Or is it already possible?
Sounds like it will be the other way around, Ikea devices will be discoverable by the Xiaomi platform.
Tip: just a couple of weeks ago I ordered a Raspbee, a small GPIO header for a Raspberry Pi, which turns your RasPi into a generic Zigbee hub to which you add a lot of Zigbee devices and control from HA. Conbee is an alternative in the form of a USB stick. I’ve added two Aqara (Xiaomi) door sensors, works very well!
