IKEA SOMRIG Shortcut Button for Deconz
Basic blueprint to use the IKEA SOMRIG Shortcut button with deCONZ.
The shortcut button has two buttons. Each button has a single, double and long-press, so multiple scenes or automations can be assigned to one button. This way up to 6 scenes or automations can be assigned.
blueprint:
  name: IKEA Somrig Shortcut Controls (for deCONZ)
  description: "## IKEA Somrig shortcut button (2 buttons)
    This device has two buttons. Each button has a single, double and long-press, so multiple scenes or automations can be assigned to one button. This way up to 6 scenes or automations can be assigned.
    Available controls:
    - Press the buttons **1** or **2**.
    - Double press the buttons **1** or **2**.
    - Press and hold the buttons **1** or **2**.
  domain: automation
  input:
    remote:
      name: SOMRIG shortcut button
      selector:
        device:
          integration: deconz
          model: SOMRIG shortcut button
          multiple: false
    button_one_press_action:
      name: Button 1 - Single press action
      description: Choose action(s) to run when the button with **ONE** dot is **pressed**.
      default: []
      selector:
        action: {}
    button_one_double_press:
      name: Button 1 - Double press event
      description: Choose action(s) to run when the button with **ONE** dot is **double pressed**.
      default: []
      selector:
        action: {}
    button_one_hold_action:
      name: Button 1 - Hold action
      description: Choose action(s) to run when the button with **ONE** is **pressed and hold**.
      default: []
      selector:
        action: {}
    button_two_press_action:
      name: Button 2 - Single press action
      description: Choose action(s) to run when the button with **TWO** dots is **pressed**.
      default: []
      selector:
        action: {}
    button_two_double_press:
      name: Button 2 - Double press event
      description: Choose action(s) to run when the button with **TWO** dots is **double pressed**.
      default: []
      selector:
        action: {}
    button_two_hold_action:
      name: Button 2 - Hold action
      description: Choose action(s) to run when the button with **TWO** dots is **pressed and hold**.
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
- platform: event
  event_type: deconz_event
  event_data:
    device_id: !input remote
- variables:
    event: '{{ trigger.event.data.event }}'
- choose:
  - conditions:
    - '{{ event == 1001 }}'
    sequence: !input button_one_hold_action
  - conditions:
    - '{{ event == 1002 }}'
    sequence: !input button_one_press_action
  - conditions:
    - '{{ event == 1004 }}'
    sequence: !input button_one_double_press
  - conditions:
    - '{{ event == 2001 }}'
    sequence: !input button_two_hold_action
  - conditions:
    - '{{ event == 2002 }}'
    sequence: !input button_two_press_action
  - conditions:
    - '{{ event == 2004 }}'
    sequence: !input button_two_double_press
Any chance you could explain how this works? After installing my Somrig in Deconz the only entity I see is the battery indicator - now showing 100%. No “switches” per se. How are Button1 and Button2 recognised without being entities?
With your blueprint used (thank you!) to create an automation I have it doing what I want but haven’t “taken control” in case I break something.
Usually this type of button exposes only battery entity. When button is pressed it generate event (deconz_event in this particular case) that can be used as trigger for automation. Details of event can be seen in Developer Tools>Events>Liosten to events. You need to put deconz_event in the Event to subscrive to field and press Start listening. All events from integration, with all event details required to identify specific trigger will be displayed below.
Thanks! Great explanation.
