### Link
https://www.ikea.com/se/sv/p/somrig--genvaegsknapp-vit-smart-50560334/…
### Database entry
{"id":14,"type":"EndDevice","ieeeAddr":"0x5cc7c1fffe61fe84","nwkAddr":46447,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery","modelId":"SOMRIG shortcut button","epList":[1,2],"endpoints":{"1":{"profId":260,"epId":1,"devId":6,"inClusterList":[0,1,3,4,32,4096,64636,64640],"outClusterList":[3,4,6,8,25,4096,64640],"clusters":{"genBasic":{"attributes":{"modelId":"SOMRIG shortcut button","manufacturerName":"IKEA of Sweden","powerSource":3,"zclVersion":8,"appVersion":1,"stackVersion":113,"hwVersion":1,"dateCode":"20230308","swBuildId":"1.0.20"}},"genPollCtrl":{"attributes":{"checkinInterval":172800}}},"binds":[{"cluster":32,"type":"endpoint","deviceIeeeAddress":"0x00124b000be8918e","endpointID":1}],"configuredReportings":[],"meta":{}},"2":{"profId":260,"epId":2,"devId":6,"inClusterList":[0,3,4,64640],"outClusterList":[3,4,6,8,64640],"clusters":{},"binds":[],"configuredReportings":[],"meta":{}}},"appVersion":1,"stackVersion":113,"hwVersion":1,"dateCode":"20230308","swBuildId":"1.0.20","zclVersion":8,"interviewCompleted":true,"meta":{},"lastSeen":1701725878866,"defaultSendRequestWhen":"active","checkinInterval":43200}
### Comments
New IKEA shortcut button, can buy in Netherlands but not listed in NL page. Tried following converter, unfortunately nothing happens/shows up in log when pressing buttons. Also not sure what I should put in exposes, Some help would be appreciated.
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const extend = require('zigbee-herdsman-converters/lib/extend');
const e = exposes.presets;
const ea = exposes.access;
const definition = {
zigbeeModel: ['SOMRIG shortcut button'], // The model ID from: Device with modelID 'lumi.sens' is not supported.
model: 'E2211', // Vendor model number, look on the device for a model number
vendor: 'IKEA', // Vendor of the device (only used for documentation and startup logging)
description: 'SOMRIG shortcut button', // Description of the device, copy from vendor site. (only used for documentation and startup logging)
fromZigbee: [], // We will add this later
toZigbee: [], // Should be empty, unless device can be controlled (e.g. lights, switches).
exposes: [e.battery()], // Defines what this device exposes, used for e.g. Home Assistant discovery and in the frontend
module.exports = definition;
### External converter
_No response_
### Supported color modes
_No response_
### Color temperature range
_No response_
