I am not sure on what “level” this is switched, so please send me in the right direction, if you know more
I have a Ikea Styrbar (4 Switch) connected to a Conbee II → deconz → phoscon → homeassistant integration.
It all seems to work except the buttons are switched:
I am using remote_button_short_release
→ dim_up
/ dim_down
and remote_button_short_release
→ turn_on
/ turn_off
to control two lamps.
But dim_up is combined with turn_off and dim_down is comined with turn_on?
Do I do anything wrong?
How can I see on which level the switch up seems to happen? So maybe I can report a the bug in the github for deconz/phoscon/home assistant integration
Any help would be appreciated :))
Here some infos about the settup if that helps somewhat:
