IKEA Styrbar (E2001/E2002) - control Multiple Light/Switch Entities (Zigbee2MQTT v2.0 Compatible)
Blueprint: IKEA Styrbar (E2001/E2002) - control Multiple Light/Switch Entities (Zigbee2MQTT v2.0 Compatible)
This Blueprint is designed for the IKEA E2001/E2002 Styrbar switch remote, tailored to work seamlessly with Zigbee2MQTT v2.0 Actions. It enables you to control multiple lights/switches (on/off and brightness control, if supported by light) with a single Styrbar switch remote.
Features:
  • Turn lights/switches on: Short press the top button (large bulb).
  • Turn lights/switches off: Long press the bottom button (small bulb).
  • Increase brightness: Hold the top button (large bulb).
  • Decrease brightness: Hold the bottom button(small bulb).
  • Customizable Actions: Assign your own Actions for left/right arrow button hold/release Actions.
  • Target switching delay: Adjust the delay after selecting different target Entities.
  • Force brightness: Enable this option and set the brightness level in order to have a specific brightness whenever you turn the light on, instead of the last set brightness.
  • Brightness change delay: Delay after each brightness level change.
  • Brightness repeat count: Maximum number of brightness level changes per Action.
  • Brightness step: Brightness change percentage.
  • Zigbee2MQTT 2.0.0+ Compatibility: Fully compatible with the latest version; no need to enable the legacy action sensor.
  • Single light/switch or Group control: Works with any Light/Switch Entity you select.
Requirements:
  • IKEA E2001/E2002 Styrbar remote control integrated with Zigbee2MQTT.
  • A single light/switch or group of lights/switches configured in Zigbee2MQTT.
  • Home Assistant with MQTT integration enabled.
Future Improvements:
  • Bug fixes?
  • I’ll probably remove Target switching delay option.
  • Might be able to use Text Helper to save selected light/switch Device ID instead of using it’s index number which will avoid controlling the wrong light/switch if you modify light/switch target Entity list.
How to Use:
  1. Import the blueprint using the link below.
  2. Create one Number Helpers for each Styrbar remote (details below).
  3. Configure the required inputs:
    • Choose the Styrbar remote control device.
    • Select the Light/Switch Entities (single or group).
    • Select the Light/Switch Number Helper matching the Styrbar remote.
  4. Configure the optional inputs:
    • Assign Actions to Left/Right Arrow button long press/release clicks.
    • Adjust additional settings like target switching delay, force brightness level, brightness change delay and step size, and maximum brightness change repeat count.
  5. Save and activate the Automation.
  6. Enjoy controlling your lights and switches with the Styrbar remote!
Number Helper Creation:
  • Icon: mdi:numeric
  • Minimum value: 0
  • Maximum value: 127 (should be sufficient)
  • Display mode: Input field
  • Step size: 1
  • Unit of measurement: Leave blank
Create one Number Helper per Styrbar remote as it will hold the index of the currently selected Light/Switch entity.
This is my first ever Blueprint, so please go easy on me. Feedback and suggestions are welcome.
This Blueprint is based on Z2M - IKEA STYRBAR remote for multiple lights done by @Spanching. I just had an idea to do away with multiple Automations requirement and wanted support for switches.
Share and Enjoy!
