Have started having issues with the Ikea Styrbar Hook an or Blueprint for my Local Tuya Lights.
The below setup has worked flawlessly in the past and has has since started to persist with issues in the past two months or so.
I am still a relative newbie but have had fun tinkering for a year or two. In short, I have a group of RGBW Downlights for the Boys Room which are exposed to Homekit for iOS Control.
There is an automation that turns the lights on Green (Dim) at 6:00am when it is time for them to get up and it works flawlessly still.
I also have a “reset” scene which was set to activate when the “Up” button was pressed on the Strybar remote and resets the rooms to full brightness and 3800k. This was to supercede any colour changes or automations in case we needed it to. This used to work perfectly.
The issue that I have is when I change the colour of the lights to red for example at 7pm for Bedtime via iOS, or if the Green “Wakeup” scene has activated, when I press “Up” on the remote, it loads the correct “Reset” scene at full brightness, then flashes back to the previous state within 1 second. Everytime.
I have confirmed that the helper input_text for the Last Controller Event is updated for each action / state change but cannot validate what the information in it means.
I am receiving this in the text helper when I press the Up function.
Changed to {"a":"on","t":1693091433.465483} triggered by state of IKEA BOYS - Control Automation turned on
Any thoughts, help, ideas or better ways to setup to integrate these remotes into HA would be greatly appreciated.
