IKEA STYRBAR four button remote (ZHA)
As a new user I can create post only with one embeded element, different IKEA dimmers will be in different posts under my profile.
The two-button switch is for simple ON/OFF + long press for dimming. The four-button switch features ON/OFF and dimming; additionally, the left/right buttons change the white light temperature, while a long press cycles through colors for RGB bulbs.
Great timing! I was just looking for a replacement to my old blueprint. I dont seem to have any options in the Styrbar selection drop down though. Any ideas?
My bad, i see this is only for ZHA. Ill keep looking for Z2M
Update: Fixed the white color temperature change function. The original code was failing due to changes in Home Assistant’s light service. It now uses the updated command structure to ensure compatibility.
