It has become a bit more complex since this thread started.
I now have the ability to control DVD player, rew/ff on chromecast, control a different room and so on…
[{"id":"17cef50e.849dcb","type":"api-call-service","z":"a787a77.9c16458","name":"media_seek","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"media_player","service":"media_seek","areaId":[],"deviceId":[],"entityId":["media_player.chromecast_vardagsrum"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":810,"y":100,"wires":[["4d74cd83.6d2184"]]},{"id":"d9c31b63.61df68","type":"function","z":"a787a77.9c16458","name":"","func":"node.log(\"Log message\");\nnode.debug(\"Variable\", msg.payload.event.device_id);\nif(msg.payload.event.device_id == \"f594d0a16628c130b023f476a35c0091\" && msg.payload.event.command == \"move\"){\n var states = global.get('homeassistant.homeAssistant.states');\n if (states[\"media_player.chromecast_vardagsrum\"].state != \"paused\"){\n var vol_black = states[\"media_player.yamaha_receiver\"].attributes.volume_level;\n \n if(flow.get(\"vol_black\") != \"\" && typeof flow.get(\"vol_black\") !== 'undefined' ){\n vol_black = flow.get(\"vol_black\");\n }else{\n vol_black = 0.5\n }\n \n if(msg.payload.event.args[0] == 0){\n msg.volume_level = vol_black + 0.02\n if (msg.volume_level > 1){\n msg.volume_level = 1;\n }\n }else{\n msg.volume_level = vol_black - 0.02\n }\n if(!isNaN(msg.volume_level)){\n flow.set(\"vol_black\", msg.volume_level);\n }\n return [msg, null, null, null, null];\n }else{\n var pos = states[\"media_player.chromecast_vardagsrum\"].attributes.media_position;\n if(msg.payload.event.args[0] == 0){\n pos = pos + 10;\n }else{\n pos = Math.max(pos - 10,0);\n }\n \n \n //msg.pos = parseFloat(msg.data.attributes.media_position+10);\n msg.payload = {\n data:{\n \"entity_id\": \"media_player.chromecast_vardagsrum\",\n \"seek_position\": pos,\n }\n }\n \n return [null, msg, null, null, null];\n }\n}else if(msg.payload.event.device_id == \"f594d0a16628c130b023f476a35c0091\" && msg.payload.event.command == \"toggle\"){\n return [null, null, msg, null, null];\n}else if(msg.payload.event.device_id == \"f594d0a16628c130b023f476a35c0091\" && msg.payload.event.command == \"step\"){\n if(msg.payload.event.args[0] == 0 && msg.payload.event.args[1] == 1 && msg.payload.event.args[2] == 0 ){\n return [null, null, null, msg, null]; \n }else if(msg.payload.event.args[0] == 1 && msg.payload.event.args[1] == 1 && msg.payload.event.args[2] == 0 ){\n return [null, null, null, null, msg]; \n }\n} ","outputs":5,"noerr":0,"initialize":"","finalize":"","libs":[],"x":600,"y":100,"wires":[["57751245.69af1c"],["17cef50e.849dcb"],["c0602dcfb008ebba"],["13c4934d.0520dd"],["da40739d2f4a3248"]]},{"id":"4d74cd83.6d2184","type":"function","z":"a787a77.9c16458","name":"{}","func":"msg = {};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":950,"y":100,"wires":[["77334a5c.9bf214"]]},{"id":"a350be847fc3e1ca","type":"function","z":"a787a77.9c16458","name":"","func":"\n\nif(msg.payload.event.device_id == \"d1bc3a6a786d78efb2cc3ca826a4a625\"){\n msg.white = flow.get(\"white\");\n \n if (msg.white == \"black\"){\n msg.payload.event.device_id = \"f594d0a16628c130b023f476a35c0091\";\n }\n}\n \nreturn msg;\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":100,"wires":[["d9c31b63.61df68"]]},{"id":"57751245.69af1c","type":"api-call-service","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"media_player","service":"volume_set","areaId":[],"deviceId":[],"entityId":["media_player.yamaha_receiver"],"data":"{ \"volume_level\": {{volume_level}} }","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":870,"y":40,"wires":[[]]},{"id":"c0602dcfb008ebba","type":"api-current-state","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"media_player.yamaha_receiver","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":0,"forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":920,"y":240,"wires":[["00c4807eb0d3d061"]]},{"id":"13c4934d.0520dd","type":"api-call-service","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"media_player","service":"turn_off","areaId":[],"deviceId":[],"entityId":["media_player.yamaha_receiver","media_player.philips_tv","media_player.chromecast_vardagsrum"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":860,"y":160,"wires":[["5afeac0d.6118c4"]]},{"id":"da40739d2f4a3248","type":"delay","z":"a787a77.9c16458","name":"","pauseType":"delay","timeout":"500","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":830,"y":380,"wires":[["44ab579e286207d6"]]},{"id":"77334a5c.9bf214","type":"delay","z":"a787a77.9c16458","name":"","pauseType":"delay","timeout":"3","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1120,"y":100,"wires":[["4d86cad9.5065c4"]]},{"id":"c7099de63cb8116f","type":"delay","z":"a787a77.9c16458","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"0.25","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":310,"y":100,"wires":[["a350be847fc3e1ca"]]},{"id":"00c4807eb0d3d061","type":"switch","z":"a787a77.9c16458","name":"","property":"data.attributes.source","propertyType":"msg","rules":[{"t":"eq","v":"HDMI3","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1190,"y":240,"wires":[["2d1495dca042b3ee"],["e317296f.17bce8"]]},{"id":"5afeac0d.6118c4","type":"delay","z":"a787a77.9c16458","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"outputs":1,"x":1120,"y":160,"wires":[["5fb4dea2.84c66"]]},{"id":"44ab579e286207d6","type":"change","z":"a787a77.9c16458","name":"","rules":[{"t":"set","p":"black","pt":"flow","to":"white","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1000,"y":380,"wires":[["cf3ae26de7ca2d98"]]},{"id":"4d86cad9.5065c4","type":"ha-wait-until","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":1,"outputs":1,"entityId":"media_player.chromecast_vardagsrum","entityIdFilterType":"exact","property":"state","comparator":"is","value":"playing","valueType":"str","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":1260,"y":100,"wires":[["957d3925.e0d4d8"]]},{"id":"d6bc8910.db2678","type":"server-events","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":1,"event_type":"zha_event","exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"waitForRunning":true,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"},{"property":"event_type","propertyType":"msg","value":"$outputData(\"eventData\").event_type","valueType":"jsonata"}],"x":130,"y":100,"wires":[["c7099de63cb8116f"]]},{"id":"2d1495dca042b3ee","type":"switch","z":"a787a77.9c16458","name":"","property":"DVD","propertyType":"flow","rules":[{"t":"eq","v":"pause","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":1350,"y":240,"wires":[["bd3f48d6019a3a78"],["19c9592ed81ae504"]]},{"id":"e317296f.17bce8","type":"api-call-service","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"media_player","service":"media_play_pause","areaId":[],"deviceId":[],"entityId":["media_player.chromecast_vardagsrum"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1510,"y":320,"wires":[[]]},{"id":"5fb4dea2.84c66","type":"api-call-service","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"light","service":"turn_off","areaId":[],"deviceId":[],"entityId":["light.taklampan"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1290,"y":160,"wires":[[]]},{"id":"cf3ae26de7ca2d98","type":"delay","z":"a787a77.9c16458","name":"","pauseType":"delay","timeout":"10","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"allowrate":false,"outputs":1,"x":1180,"y":380,"wires":[["00805e1b3ca012a9"]]},{"id":"957d3925.e0d4d8","type":"api-call-service","z":"a787a77.9c16458","name":"rew","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"media_player","service":"media_pause","areaId":[],"deviceId":[],"entityId":["media_player.chromecast_vardagsrum"],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1390,"y":100,"wires":[[]]},{"id":"bd3f48d6019a3a78","type":"api-call-service","z":"a787a77.9c16458","name":"play","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"remote","service":"send_command","areaId":[],"deviceId":[],"entityId":["remote.broadlink_4_remote"],"data":"{\t \"device\": \"DVD\",\t \"command\": \"play\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1510,"y":200,"wires":[["e1a6c18a92beb08c"]]},{"id":"19c9592ed81ae504","type":"api-call-service","z":"a787a77.9c16458","name":"pause","server":"4bbca37b.1700ec","version":5,"debugenabled":false,"domain":"remote","service":"send_command","areaId":[],"deviceId":[],"entityId":["remote.broadlink_4_remote"],"data":"{\t \"device\": \"DVD\",\t \"command\": \"pause\"\t}","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1510,"y":260,"wires":[["808bdfaab03ac2a0"]]},{"id":"00805e1b3ca012a9","type":"change","z":"a787a77.9c16458","name":"","rules":[{"t":"set","p":"black","pt":"flow","to":"","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1360,"y":380,"wires":[[]]},{"id":"e1a6c18a92beb08c","type":"change","z":"a787a77.9c16458","name":"play","rules":[{"t":"set","p":"DVD","pt":"flow","to":"play","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1690,"y":200,"wires":[[]]},{"id":"808bdfaab03ac2a0","type":"change","z":"a787a77.9c16458","name":"pause","rules":[{"t":"set","p":"DVD","pt":"flow","to":"pause","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1690,"y":260,"wires":[[]]},{"id":"de1498ed6519868e","type":"server-state-changed","z":"a787a77.9c16458","name":"","server":"4bbca37b.1700ec","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"media_player.yamaha_receiver","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":false,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":220,"y":200,"wires":[["3d7004f641ef8567"]]},{"id":"3d7004f641ef8567","type":"change","z":"a787a77.9c16458","name":"","rules":[{"t":"set","p":"vol_black","pt":"flow","to":"data.new_state.attributes.volume_level","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":510,"y":200,"wires":[[]]},{"id":"4bbca37b.1700ec","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
The first function node is the one that switches the black knob to “emulate” being white. The black one is in the living room and the white is in the kitchen. So triple press means switch for 10 seconds (fifth output of the second function node).
If you don´t need this then you can just remove the nodes from the fifth output and the first function node.
The state changed node below takes manual (IR or physical) volume changes and updates the value in the sequence.
