IKEA Tradfi vs Rodret switch
I was using an IKEA tradfri simple switch to control some lights via very simple automations with ZHA and a raspberry Pi 4. The last days, the tradfri switch got broken and I bought the newer version, the rodret switch, and synchronized it with ZHA. When I press a button a see the event fired in the log of the device.
The problem comes when I want to build automations. I used a blank automation, choosing device as trigger and choosing “turn on button pressed”, “turn off button pressed” or similar. With the new rodret switch, I can only choose between “device offline”, “Battery level changes” and “Identify has been pressed”. The “turn on button” etc does not appear and I cannot use it as trigger for an action later (in my case to toggle a smart plug).
Do you have some hint how to solve or approach the problem?
Many thanks in advance!
