Hi!
Just recently installed ConBee II and deConz. Got it to work but having a hard time to add my devices.
Bulbs does not get added.
I could add the remote control after I pushed the ‘install’ button many times.
Motion sensor also after I pushed a lot of times on then small button on the backside.
The outlets does not have this button, how can i add those?
In the Phoscon app do a search for bulbs and then reset the bulb:
- Have the light ON
- Switch it OFF and back ON 6 times (in total, the light will be ON again 6 times without counting the initial ON state)
- Wait in the 6th ON state, the bulb should increase brightness intensity to confirm reset
- If the light didn’t confirm reset, try to leave the bulb ON less than a second, and OFF longer. The timing of ON/OFF states may matter for some firmware versions;
For the outlet:
In phoscon, search for switch and reset outlet:
To factory reset the TRADFRI control outlet, press and hold the reset button (pinhole underneath the light, located at the top (bottom if UK) of the outlet) with a paperclip until the white light starts fading. Hold onto the button for a few more seconds, then release. After this, the outlet will automatically connect.
Thanks for the reply!
I managed to add the lamp bulbs, will the reset by paper clip and and add those today.
I got the outlet connected but it was little tricky as I had add them as lights.
