IKEA Tradfri Bulb Reset / Pairing Mode Sequence
Hi everyone,
I created a Script Blueprint to automate the reset sequence for IKEA Tradfri bulbs to get them into pairing mode.
As many of you know, resetting these bulbs requires toggling the power 6 times (or 5 in some firmware versions) with very specific timing. Doing this manually with a wall switch or toggling a dashboard button is tedious and often fails if the timing is off.
This blueprint creates a script that handles the timing perfectly using a smart plug or relay.
What it does:
It targets a Smart Plug (or Switch/Relay) and toggles the power 5 times with a 900ms OFF / 500ms ON delay pattern.
Prerequisites:
  • The IKEA bulb you want to reset must be plugged into a Smart Plug or controlled by a Smart Switch/Relay that is already in Home Assistant.
The Blueprint
Click the badge to import this Blueprint directly into your Home Assistant instance:
Open your Home Assistant instance and show the blueprint import dialog with a specific blueprint URL pre-filled.
Or import using this URL:
https://github.com/droidgren/home_assistant/blob/main/blueprints/IKEA_Bulb_reset.yaml
How to use
  1. Import the blueprint.
  2. Create a new script from the blueprint (Settings > Automations & Scenes > Scripts > Add Script).
  3. Select the Switch or Light entity that physically cuts power to your IKEA bulb.
  4. Run the script!
Hope this helps anyone struggling with pairing mode!
Hah! Using one form of automation as a tool to make another easier. Taps side of head. Nifty.
30 different tries with 2 bulbs in different lamps, i thought i was going crazy. Let my SO try it, no success. Tried your script; first try!
Thank you so much!
Thank you. It did work first time running this script!
