I have many of this switches and I wanted a simple configuration. So you only setup the Switch as source, and set a Target Light. No further Action needed.
What it does (not configurable!):
Clicking "off or “on” will toggle the light.
Holding “on” will increase brightness.
Holding “off” will decrease brightness.
Brightness is changed by 5% every 0,2s.
Releasing “on” or “off” will stop changing brightness.
I tested availble blueprint from EPMatt and Kroning for this switch, but none worked like I want. By behavour or bugs.
I think the blueprint from EPMatt has bugs with changing brightness and it was too complicated to setup. I tried to trace it down, but failed. Also I dont want to need to create for each switch a helper text entity for “Last Controller Event”
I wanted a KISS solution Works for me. And I am willing to share. maybe its helpfull for someone.
@xbmcnut you asked for it in gist, but I couldn’t paste the code there properly. So try here. Here are my little additions to the already excellent Blueprint:
blueprint:
name: Z2M - Tradfri E1743 Switch On Off Dimming Light
description:
"Controls a light with a switch given by ENTITY. \n\n Short Button press
will toggle light for both Buttons (helpfull in darkness) \n\n Mode set to restart
is mandatory for stop after long press to work."
domain: automation
input:
source_switch_action:
name: Tradfri E1743 Switch
description: The switch-action which triggers this automation.
selector:
entity:
filter:
- integration: mqtt
domain:
- sensor
multiple: false
target_light:
description: the light you want to control.
selector:
target: {}
force_brightness:
name: Force turn on brightness
description: >
Force the brightness to the set level below, when the "on" button on
the remote is pushed and lights turn on.
default: false
selector:
boolean:
brightness:
description: Brightness of the light(s) when turning on
default: 100
selector:
number:
min: 0
max: 100
mode: slider
step: 1
unit_of_measurement: "%"
helper_transition_dim:
name: Helper - Transition time for dimming up / down
description: Transition time in seconds for dimming up / down. 0 makes visible steps. Greater than 0.1 makes it smoother. (0.0-10.0)
default: 0.5
selector:
number:
min: 0.0
max: 10.0
mode: box
step: 0.5
helper_delay:
name: Helper - Delay between each dimming step
description: How long should be delayed between each step of dimming in milliseconds. 0 makes no delay. (10-2000)
default: 200
selector:
number:
min: 10
max: 2000
mode: box
step: 10
#source_url: https://gist.github.com/FloppyGit/efaa93c1d63676e30c4b61adb4a861ac
alias: Z2M - Tradfri E1743 Switch On Off Dimming Light
description: ""
variables:
force_brightness: !input force_brightness
- platform: state
entity_id: !input source_switch_action
to: "on"
- platform: state
to: "off"
- platform: state
to: brightness_move_up
- platform: state
to: brightness_move_down
- platform: state
to: brightness_stop
condition: []
- variables:
command: "{{ trigger.to_state.state }}"
- choose:
- conditions:
- condition: trigger
id:
- "on"
sequence:
- choose:
- conditions: "{{ force_brightness }}"
sequence:
- service: light.toggle
target: !input target_light
brightness_pct: !input brightness
default:
data: {}
- conditions:
id:
- "off"
sequence:
data: {}
- conditions:
id:
- brightness_move_up
sequence:
- repeat:
sequence:
- service: light.turn_on
brightness_step_pct: 5
transition: !input helper_transition_dim
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: !input helper_delay
count: 50
- conditions:
id:
- brightness_move_down
sequence:
- repeat:
sequence:
brightness_step_pct: -5
- delay:
hours: 0
minutes: 0
seconds: 0
count: 50
mode: restart
